code p0505??????idle prob
Old May 19, 2005 | 08:12 PM
urnotfast's Avatar
Default code p0505??????idle prob
i have a code p0505 (idle control system malfunction) in my 99 si. when the mil comes on the idle goes to 2 grand and if i clear the code the idle drops back down to normal. but it comes back a day later does anyone know what might cause this.
Old May 19, 2005 | 09:27 PM
urnotfast's Avatar
Default Re: code p0505??????idle prob (urnotfast)
up
Old May 20, 2005 | 06:46 AM
urnotfast's Avatar
still looking for any suggestions
Old May 20, 2005 | 07:18 AM
Filthy Focker!'s Avatar
Try this:
remove the air duct from the throttle body.
Start your car and block with your fingers the lower port in the throttle body
If the engine stalls, then you need to check the IAC for proper tuning. If it is within spec, you will then need to replace it.
If not, check for vacuum leaks.
Old May 20, 2005 | 04:36 PM
urnotfast's Avatar
Default Re: code p0505??????idle prob (filthy)
thanks ill try that in the morning
SlipGear
Jun 26, 2008 05:37 PM
99GreenEX
12
Feb 22, 2008 09:54 AM
Problemo
Jan 29, 2006 04:16 PM
UNKNOWN_MEMBER
Jun 27, 2005 08:15 AM
