Friend just got her B16A got some questions???
Old Feb 5, 2002 | 07:58 PM
chirp3rd's Avatar
Default Friend just got her B16A got some questions???
Ok listen we just got a B16a 1st gen. for a 91 hf and the harness on the engine is kinda of cut, i wanna know if the HF stock harness can be used on the motor or what modifications that are needed. Also the distributor cap is broken which cap do we have to buy for this motor????
I did a search and it really didnt help me so some1 please help me out?????
Old Feb 6, 2002 | 01:02 AM
brad.'s Avatar
Default Re: Friend just got her B16A got some questions??? (chirp3rd)
HF harness requires alot of changing due to the dual port fuel injection....i would reccomend an Si wire harness
for the cap you're gonna use one off of a 91 Integ
Old Feb 6, 2002 | 02:23 AM
CRX-RX's Avatar
Default Re: Friend just got her B16A got some questions??? ([626]JDM-b16a-EF9)
If her HF is MPFI then you can use it, you just need to add VTEC like in an Si harness, and remove a couple extra pins.
Old Feb 6, 2002 | 03:11 AM
TypeR0207's Avatar
Default Re: Friend just got her B16A got some questions??? (CRX-RX)
HF is MPFI already.
Go to http://hybrid.honda-perf.org/tech/4gtech.html and read up on it .....
Old Feb 6, 2002 | 04:04 AM
Brandon Chun's Avatar
Si harness 3 or 4 wires.
Old Feb 6, 2002 | 04:49 AM
Superhatch's Avatar
Default Re: Friend just got her B16A got some questions??? (Brandon Chun)
or goto http://www.hasport.com , they have a good section on wiring.
Old Feb 6, 2002 | 07:14 AM
chirp3rd's Avatar
what about the distrubitor cap which one do i use????
Old Feb 6, 2002 | 12:10 PM
brad.'s Avatar
didn't i tell you, 91 integra
crx89backedout
Jan 14, 2010 03:36 AM
hondaex99
Jan 11, 2010 10:04 PM
Daneish
Apr 4, 2004 06:42 AM
ITSTOCK
Nov 15, 2003 03:51 PM
chirp3rd
Feb 7, 2002 05:02 PM
