OBD2 Injectors. Will it mess up anything?
Old May 19, 2005 | 07:18 PM
Power Rev Racing's Avatar
Default OBD2 Injectors. Will it mess up anything?
I have a 91 civic dx. Dual point injection. I am putting a b16. The engine is OBD2. But i am running a obd0 b16 ecu. Will i be able to use the injectors that are on the motor? Or will the ecu give trouble. ALso if it will work do i need to wire up the resistor box, or leave it out?
Old May 19, 2005 | 09:15 PM
4drEF's Avatar
Keyboard Humorist
Default Re: OBD2 Injectors. Will it mess up anything? (Power Rev Racing)
To use the preOBD (OBD-0) ECU it expects to see a high impedance from the injectors.
Since preOBD injectors are low impedance you MUST use the resistor box.
OBD2 and OBD1 injectors are both high impedance.
You can run them just fine with your preOBD ECU by NOT using the resistor box.
Old May 19, 2005 | 10:46 PM
jdmEFsedan's Avatar
Default Re: OBD2 Injectors. Will it mess up anything? (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">To use the preOBD (OBD-0) ECU it expects to see a high impedance from the injectors.
You can run them just fine with your preOBD ECU by NOT using the resistor box.</TD></TR></TABLE>
...exactly...and to delete the resistor box...just connect all the wires together...or buy the plug from LoCash. Don't forget about the OBD2 injector plugs!!
Hope this helps.
Old May 20, 2005 | 10:20 AM
Default Re: OBD2 Injectors. Will it mess up anything? (jdmefsedan)
Ok thanks alot.
I have a OBD 2 wire harness. so i will use the injector clips from that harness
Navy_Kyle
Aug 6, 2012 12:41 PM
jamescodylee
May 3, 2011 07:52 AM
e jay one
Aug 6, 2005 02:48 PM
hypa
May 20, 2003 03:48 AM
VTECVillain
Jul 14, 2002 05:14 AM
