Car still wont start!!! Help!!!
Old Feb 5, 2002 | 07:35 PM
big pete's Avatar
Default Car still wont start!!! Help!!!
i replace the dist. and it still doesnt start.....it cranks but no spark.....does anyone have any suggestions of what else it could be?? any help appreciated
Old Feb 5, 2002 | 07:37 PM
Stinkalope's Avatar
New User
Default Re: Car still wont start!!! Help!!! (big pete)
make sure the ignitor is mounted (grounded) correctly in the dist....
Old Feb 5, 2002 | 07:39 PM
CLICC916's Avatar
i'm sure you double checked your basic electrical stuff (spark plugs, sparkplug wire, fuses, etc.) is it cranking with power? check your timing belt to see if it could be slipping, it happened on my friend's car
Old Feb 5, 2002 | 07:42 PM
inzane's Avatar
have you tried the starter that might be your problem if it cranks
Old Feb 5, 2002 | 08:53 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Its possible its the ecu too....just to throw that out
If you want to tow the car to livermore i have a spare pr3 u can try.
-Todd
Old Feb 5, 2002 | 10:20 PM
balistic CRX's Avatar
Default Re: Car still wont start!!! Help!!! (GymkhanaGTI)
try putting it in TDC. may that will work. and also check your timing belt.
Old Feb 6, 2002 | 03:51 AM
vsual's Avatar
big pete...you did a swap on your car right??what motor??
things to look for.....code errors?? bad grounding?? timing??
by the ways what part of norcal do you live at??if i have time i may be able to check it out.let me know
Old Feb 6, 2002 | 07:46 AM
crxracer's Avatar
If you have replaced the distributor, ignitor and checked all the wires, plugs and connections there still may be one more item that from time to time goes bad. It is the main relay. It is located up under the dash on the drivers side and looks like a black box about 3" long. Borrow one from a buddys car and see if it makes any difference.
Old Feb 6, 2002 | 11:01 AM
big pete's Avatar
Default Re: Car still wont start!!! Help!!! (crxracer)
thanks guys.......im gunna try checkin the main relay.......and the dist isnt upside down.......and vasual......im in sf
Old Feb 6, 2002 | 08:12 PM
big pete's Avatar
Default Re: Car still wont start!!! Help!!! (DOHC DX)
its not upside down....it has spark...i check it today....i think it might be the main relay...my car is gettin towed to my uncles shop tomorrow....ill let you guys know what the problem is....thanks
Old Feb 8, 2002 | 12:31 PM
big pete's Avatar
well i just got my car checked and the timing belt did slip.....had spark but the belt slipped....gunna get a new belt tomorrow
Old Feb 8, 2002 | 02:55 PM
Stinkalope's Avatar
New User
If this solves the problem, I assume it retarded the ign a lot? The reason I ask is that my car acts extremely retarded. I have my dist advanced all the way towards the firewall as far as it will go. I am going to check it sun and try to find the probem, but it bogs and coughs when I back the dist off any.
Old Feb 9, 2002 | 08:42 PM
deepnite's Avatar
alternator
[713]
May 14, 2012 03:23 PM
Lao17
12
Aug 2, 2011 01:49 PM
nighttrain33
Mar 23, 2008 01:38 PM
EJ ITO
26
Mar 22, 2007 05:41 AM
96_9c1
Jul 24, 2006 03:08 PM
