Build up for a 99 LS Motor....Suggestions?
Old May 19, 2005 | 05:57 PM
JoeHatch's Avatar
Default Build up for a 99 LS Motor....Suggestions?
Should i go with a GSR throttle body with 66mm????
Old May 19, 2005 | 05:58 PM
JoeHatch's Avatar
Default Re: Build up for a 99 LS Motor....Suggestions? (LSCivic#1)
what ECU should install a regular stock LS ECU with a chip or somehting else???
Old May 19, 2005 | 05:59 PM
TrackSpeedRacing's Avatar
more information regarding your build would help out alot. let us know
Old May 19, 2005 | 06:20 PM
JoeHatch's Avatar
well i have a ls motor and tranny all stock with a stage 1 skunk2 cams that is all i have now i need to know what computer shall i install leave it stock and chip it out. also the throotle body should i convert it to GSR so its bigger?
Old May 19, 2005 | 06:27 PM
ExospeedAMcrx's Avatar
SKunk makes non-vtec cams? or you have a VTEC head?
Old May 19, 2005 | 08:59 PM
hybrid_vtec's Avatar
Default Re: Build up for a 99 LS Motor....Suggestions? (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">SKunk makes non-vtec cams? or you have a VTEC head?</TD></TR></TABLE>
Skunk does not make nonvtec cams!
Old May 20, 2005 | 10:03 PM
GEIJIN's Avatar
man go with a itr throttle body better flow. what comp are you running? any head work?
Old May 20, 2005 | 10:51 PM
DFW's Avatar
DFW
Default Re: Build up for a 99 LS Motor....Suggestions? (fourdoorek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320JDMGSR &raquo;</TD></TR><TR><TD CLASS="quote">more information regarding your build would help out alot. let us know </TD></TR></TABLE>
lsteg94
Sep 4, 2007 01:48 PM
Beau Gotti
Feb 22, 2006 08:57 PM
blaxican05
18
Nov 27, 2005 08:07 AM
Truecure
Jun 1, 2005 03:46 PM
stevanhulk
Jul 30, 2003 04:23 AM
