gsr into an ek
Old May 19, 2005 | 05:16 PM
xoutlawz00x's Avatar
Default gsr into an ek
i got a gsr motor im bout to drop in a 98 dx.. and the motor came with all the integra mounts.. and have the stock d series engine in now.. now i know to the do swap im gonna need 99-00 si rear tranny mount and driver side mount.. and are the rest of the mounts gonna be my d series or the b sereies that came with the engine???
thanks
Old May 19, 2005 | 05:34 PM
Built to Spill's Avatar
el diablo
Default Re: gsr into an ek (xoutlawz00x)
All the mounts from the GSR motor will work on your car.
Old May 19, 2005 | 05:35 PM
Default Re: gsr into an ek (Built to Spill)
okay thanks
Old May 19, 2005 | 05:38 PM
so all the mounts on my d series except the rear tranny mound and driver side mount are the same As the gsr mounts??
Old May 19, 2005 | 05:39 PM
and another question are all gsr mounts the same as 99-00 si mounts
Old May 19, 2005 | 05:42 PM
el diablo
Your d-series mounts are different from the b-series mounts. What im saying is <U>all</U> the mounts from your gsr motor will bolt up to the mounting locations in your cars engine bay.
Old May 19, 2005 | 05:48 PM
okay thanks.. im gonna use all my gsr mounts.. but.. if i didn't have them then i would need 99-00 si rear tranny mount and driver side mount with the rest my stock d series.. can i do that??
Old May 19, 2005 | 05:52 PM
el diablo
I dont know which d-series mounts would (if any) be interchangable with your b-series mounts. Even if some of your d-series mounts worked, why would you want mounts designed for a d-series on a b-series motor? The d-series mounts wont last on a gsr motor. Do you not have all the gsr mounts?
Old May 19, 2005 | 06:07 PM
no im just wondering if i can do taht??? i just wanna know my options
Old May 22, 2005 | 05:54 PM
CAn anyone confirm that all the jdm gsr(for a jdm gsr engine) mounts will work in an ek hacth..
Old May 22, 2005 | 06:42 PM
SleepnCiViC's Avatar
yeh jus use the gsr mounts and ull be on your way
Old May 22, 2005 | 06:49 PM
Status Sean's Avatar
Default Re: (SleepnCiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">yeh jus use the gsr mounts and ull be on your way </TD></TR></TABLE>
xwhitchx
15
Jun 19, 2009 08:30 PM
ek9child
Jun 11, 2007 07:12 AM
ForceFed Coupe
Dec 13, 2003 04:19 PM
BigIslandBoi
Aug 27, 2003 02:57 PM
