electrical problem
Old May 19, 2005 | 03:26 PM
Special-K-Coupe's Avatar
Default electrical problem
i friend just gave her crx si...but the catch is there is something wrong with the electrical...from what i know her ex try to put sounds...heres the problem....battery must be unplugged anytime or it dies...corner lights stay on even if switch is off, no light in cluster, and radio doesn't turn on...would i have to do all of the electrical??? need help please
Old May 19, 2005 | 06:22 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: electrical problem (Special-K-Coupe)
first of all check your fuses... <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Special-K-Coupe &raquo;</TD></TR><TR><TD CLASS="quote">corner lights stay on even if switch is off</TD></TR></TABLE>
the switch might've been bypassed or a stuck "on" switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Special-K-Coupe &raquo;</TD></TR><TR><TD CLASS="quote">no light in cluster</TD></TR></TABLE>
blown fuse, blow bulb... replace both if blown, if it keeps blowing then there's a short to power, fuse with a wrong amp rating, blah blkah blah
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Special-K-Coupe &raquo;</TD></TR><TR><TD CLASS="quote"> and radio doesn't turn on</TD></TR></TABLE>
check the fuse once again, check the harness... it would be easier if you have access to a volt meter, continuity tester or even a test light
Old May 20, 2005 | 09:52 PM
Default Re: electrical problem (BrokeAssPinoy)
i checked all the fuses...they are all good...how can i check if the switch was bypassed? i seen wires cut and taped???
Old May 20, 2005 | 09:57 PM
totally omit and remove the switch, if it;s still turned on then it's been bypassed
Old May 20, 2005 | 10:03 PM
bump does anyone here have a schematic/ lelectrical diagrams?
DC5Danny
Mar 22, 2007 08:01 AM
NAmodified
Dec 5, 2006 11:34 AM
thegod
Jul 7, 2006 11:18 AM
dajoyner
Jun 18, 2006 11:23 AM
d0nk1llum1nati
May 8, 2006 04:54 PM
