FS: SpeedingHatch's H22 Turbo Civic Hatch *nice build project*
Well, Ive reached a crossroad, and either I sell it, or I build it.
So I am putting up my civic up for sale.
Currently, it runs, but not well. I'd definetely recommend getting it towed home if there is interest.
There is massive blowby so Im assuming the rings and pistons are shot, but I havent cracked open the motor yet.
On with the specs:
1992 civic cx - clean title
HCP h22a mounts
JDM h22a
M2B4 LSD tranny
USDM H22a pistons (10:1cr)
ACT clutch
ACT lightened flywheel
DSM 450's
Borgwarner t3/t4 54 trim turbo
TurboXS manual boost controller
Drag Cast manifold
Tial 38mm wastegate
Street Imports 21x9x3 - painted black for sleeper look
3" DP
3" straight through exhaust
p72 with uberdata - tuned
1g DSM BOV
standard oil lines
New timing belt
New balance shaft seal with retainer
DSS Stage 1 axles , *brand new driver side axle*
Custom Rate H22 civic Ground Control coilovers
KYB AGX shocks
16" Rota Oversteer.aka Track R, aka CPR copies
205/40/16 Yokohama Parada spec 2 (like 97% tread left)
VIS CF duckbill
"Spoon" Mirrors
MAd jdm tytness amber corners
VDO boost gauge
Sunpro tach
Uhhh, i think thats it. On with some pics:
and the rims
During the motor's life, it made 354whp, so it has potential. However, this was with a 12psi spike @6k rpm, and clearly the piston(s) decided to go after awhile.
I guess Im just seeing if there is interest, but if I had to put a price on it, id say......
5000 with rims
4500 on 13" steelies
It would be a cheap fix to put in new pistons and rings in, but Id recommend building the block.
Thanks
<FONT SIZE="20">As of 5/31 the motor is out and everything to be parted out!!! </FONT>
Modified by SpeedingHatch at 12:18 AM 5/31/2005
On with the specs:
HCP h22a mounts
JDM h22a
M2B4 LSD tranny
ACT clutch
DSM 450's
Drag Cast manifold
Tial 38mm wastegate
3" DP
1g DSM BOV
standard oil lines
New timing belt
KYB AGX shocks
VIS CF duckbill
"Spoon" Mirrors
VDO boost gauge
Sunpro tach
and the rims
5000 with rims
Thanks
thanks for the bumps fella's. Ive already started tearing her down to be parted out, so if you want anything, PM me.
Im talking like, head, radiator, cams, tranny (when i pull it), wiring harness, mounts. ANYTHING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDAFIEND- »</TD></TR><TR><TD CLASS="quote">that was sick run when she blew much props, bump for a guy who built and blew a fastass EG
.</TD></TR></TABLE>
thanks bro, it WAS fast
.</TD></TR></TABLE>thanks bro, it WAS fast
