IAT SENSOR B16/b18
does anyone know if the IAT sensor for a b16a2 has the same connector as a 99 gsr engine harness.
reason i asked is because i bought a IAT sensor for a b16a2 (my motor) and it doens't seem to fit the obd2 gsr engine harness i am using.
if i remember, the IAT on the gsr is in the intake manifold. and the a2 it is in the intake arm. if you get the correct 2 pin connector, just splice and solder you will be fine.
