anybody have an uberdata basemap for stock type r
make one simply by taking a JDM P30 and rescaling the fuel table for a 1.8L, the ign maps on the JDM P30 are better then a stock R and i've done this for my friend's car who has a 98 Spec swap in his 00 Si with a chipped P28
I have a stock ITR base map, but you can't modify it using uberdata. If you have Chrome you can edit there, otherwise you can just burn it and use it as a stock ITR chip.
The person above is correct though, that a jdm p30 map has better ignition curves.
here i'll help you out:
http://www.mrapg.net/P73%20Remap.bin
just adjust the rev limits and vtec points and your set
nexgen91
Engine Management and Tuning
Jan 2, 2015 07:16 AM
