Does anyone make a 3" diameter CAI for the CRX?
Old Feb 5, 2002 | 07:04 PM
EFing8's Avatar
Default Does anyone make a 3" diameter CAI for the CRX?
Does anyone make a 3" diameter CAI for the CRX? Cuz I can't seem to find one.
Old Feb 5, 2002 | 07:08 PM
bryant's Avatar
Default Re: Does anyone make a 3" diameter CAI for the CRX? (CND_CRX)
the 99-00 civic Si one will fit. but you will need to relocate your battery.
Old Feb 5, 2002 | 07:12 PM
EFing8's Avatar
Default Re: Does anyone make a 3" diameter CAI for the CRX? (CR-X)
I know, but I really don't want to relocate.
Old Feb 5, 2002 | 07:20 PM
FUP23's Avatar
New User
Someone please help me relocate!!!! I have sanded down to bare metal for grounds and it will never turn over!!!! Whats up with this ? Ugh it sucks
Old Feb 5, 2002 | 07:29 PM
Stinkalope's Avatar
New User
Default Re: Does anyone make a 3" diameter CAI for the CRX? (Devin17)
Sounds like your ground even though you sanded down. Just incase, double check your power wire on your starter, that has caused trouble many times, it might have got yanked off in the process. Also double check you positive wire into the box and make sure that you fuses in that box are all good.
Old Feb 5, 2002 | 08:18 PM
ZCREX's Avatar
Default Re: Does anyone make a 3" diameter CAI for the CRX? (Stinkalope)
ground on your thermostat man
Old Feb 5, 2002 | 09:36 PM
JDM_DOHC_SiR's Avatar
New User
Injen with IceMan Cold Air Addaptor..But I think that IceMan makes a larger Diameter Intake for 1.8 swaps in EF's.
[Modified by JDM_DOHC_SiR, 3:39 PM 2/6/2002]
Old Feb 6, 2002 | 04:58 AM
keithv's Avatar
did you have the ground strap going from the valve cover to the chassis?
Old Feb 6, 2002 | 07:14 AM
FUP23's Avatar
New User
Default Re: Does anyone make a 3" diameter CAI for the CRX? (breaka_1_9)
Yeah man, I had that.
What do you mean ground to my thermostat ? You lost me there. I also made 2 grounds in the back, liek they do stock. Still , lights will come on radio etc. Just no motor. Are you sure the AEM 99-00 intake will fit before I go and buy it . ?
Old Feb 6, 2002 | 07:24 AM
freud's Avatar
There's a ground that attaches to the thermostat. Make sure it's connected properly. You're car wil not start without it.
Old Feb 6, 2002 | 07:28 AM
FUP23's Avatar
New User
Default Re: Does anyone make a 3" diameter CAI for the CRX? (freud)
Ah gotcha. Yea it was attached. It started up fine when i moved the battry back up front. S o it has to be a ground, But damn where do i ground this thing in the back. Its impossible lol
Old Feb 6, 2002 | 11:49 AM
Overkll's Avatar
Default Battery
Is your battery new? You should check the voltage you're getting at the front of the car. You might not be getting enough power up there to turn it over. What size cable are you running? If you ground down to bare metal and it's still not turning over, it's gotta be either a connection, a fuse, or the battery just isn't up to the task of pumping enough voltage through 15 feet of wire. HTH Kerry
Dre90
Apr 1, 2010 07:51 PM
Mr. Giggles
Jul 9, 2006 06:02 PM
tommycrx
Mar 31, 2003 07:16 PM
turbohf
23
Feb 18, 2003 12:24 AM
dingusjt
Nov 11, 2002 06:59 PM
