speedo MPH off
Old May 19, 2005 | 01:30 PM
dso's Avatar
dso
Default speedo MPH off
ok so i've searched already under "speedo", "speedo off", "speedo mph", and all of the posts i read had no help. My speedo is off by 5mph, i know it's not that much, but it's annoying and i would like to be able to fix it. So if anyone could make some suggestions they would be greatly appreciated.
Old May 19, 2005 | 01:35 PM
SOHC4life 96's Avatar
Default Re: speedo MPH off (the blackhole)
Use a fork to pop the needle off. Get a friend to drive next to you and tell you how fast he is going then put your needle on for that speed. I've done this with my friend close to 15 times and it works everytime.
Disclaimer: I'm not responsible for anything that happens to your cluster. This is mearly a suggestion.
Old May 19, 2005 | 01:38 PM
Marauder's Avatar
Default Re: speedo MPH off (SOHC4life 96)
My '00 civic EX is just like that. I just live with it, and drive 5 mph faster.
Old May 19, 2005 | 01:39 PM
nocturnaldragon's Avatar
read the how to in my sig.
Old May 19, 2005 | 02:00 PM
Morning Call's Avatar
just popping the needle off wont do nothing
it could be in his tire size/pressure too
the speedometer doesnt stay 5mph off throught the speed range.. its generally a %.. and not a set value
if he was doing 50mph and his speedo read 55mph... and he set his needle to 55 to fix it, at 80mph his needle could show 90mph..
fix it the right way
Old May 19, 2005 | 02:49 PM
Default Re: (Morning Call)
please enlighten use on how to do it the right way then, because the way in my Sig WILL WORK just fine many people have ussed it and said it works great not to mention it says right in it, it will only work if its off consistantly at any given speed......... Grrrrrrrrrrrrrrrr
Old May 19, 2005 | 03:10 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the blackhole &raquo;</TD></TR><TR><TD CLASS="quote">ok so i've searched already under "speedo", "speedo off", "speedo mph", and all of the posts i read had no help. My speedo is off by 5mph, i know it's not that much, but it's annoying and i would like to be able to fix it. So if anyone could make some suggestions they would be greatly appreciated.</TD></TR></TABLE>
what size tires are u running? honda speedos usually read higher than actual by about 5mph. i just went from 13" -&gt; 15" wheels and my speedo became corrected
Old May 19, 2005 | 03:31 PM
YCT's Avatar
YCT
Default Re: speedo MPH off (dantastic)
u can pop the needle off?
Old May 19, 2005 | 05:14 PM
dso's Avatar
dso
i have the '00 si rims and 205/45/15 ecsta supras. i figured the tire sizes i chose wouldn't through off the speedo, maybe i'm wrong... am i?
koumatae
Nov 5, 2011 04:18 PM
meandino
Dec 25, 2009 06:40 AM
213374U
May 18, 2009 02:08 AM
mizzoEG
Sep 10, 2007 09:04 PM
civexspeedy
Jan 31, 2007 01:34 PM
