NEED HELP ON MY REX
Old May 19, 2005 | 01:30 PM
shawnCRX's Avatar
Default NEED HELP ON MY REX
hi fellow rex drivers. ok...heres my story...
i bought an 87 crx 2seat hatchback si 5speed with the b15 or something like that i dont even know...im a noob to the sport and would really appreciate a path to start with. Its rear fenders are rusted, and the rear bumper support is almost gone. Also, i recently sprung an anti-freeze leak and im hopeing its the water pump that i'll be replacing tonight. very mad and ready to give up on my rex because it seems to be giving up on me. GIMME SOME ANSWERS PLEEEZ
~shawn~
Old May 19, 2005 | 01:47 PM
Blue Hybrid's Avatar
Default Re: NEED HELP ON MY REX (shawnCRX)
do you want to go fast? or do you want a reliable car?
Old May 19, 2005 | 01:52 PM
shawn_crx's Avatar
Default Re: NEED HELP ON MY REX (gold EF)
Nice Name..
I'll say Swap the engine. probably cheaper than repairing it.
Old May 19, 2005 | 02:11 PM
shawnCRX's Avatar
well, i want a good clean car....kind of tuner look but nothing to exotic ya know. and then on top of that i want people to barely see my nice ride when im flyin past them. so in other words, a nice looking car, that goes fast, and is cheaper than what i can come up with
shawn
Old May 19, 2005 | 05:56 PM
ive tried everything B16a, Lsvtec, B18c Turbo, and to tell you the truth, if i had to start all over, id go ZC turbo. its like 200 lbs lighter than the B series and you can make it faster with a turbo, and it bolts right in and plugs right in, i currently have a b16a nitrous motor in my hatch because i blew up my lsvtec on nitrous. and like i said, if i could start over, id go zc turbo
Old May 19, 2005 | 06:56 PM
shawnCRX's Avatar
well....i heard that the ZC doesnt bolt right down into the engine compartment and i'd have to get special mounts...and re wireing is a bitch??? idk
Old May 19, 2005 | 07:27 PM
Kwicko's Avatar
Well, it's not a ZC, but it's pretty similar... Try an '86 or '87 Integra engine. It should drop right into your CRX, use the existing mounts and wiring, and I *think* even use the Si transmission. Probably the easiest first-gen ('84-'87) CRX swap there is. The Integra made around 117hp in the US, compared to your '87 Si's 91hp stock.
Mike
Old May 19, 2005 | 08:03 PM
shawnCRX's Avatar
Default Re: NEED HELP ON MY REX (Kwicko)
thanx i will look into that is it called the b16a1? or something like that?
Old May 20, 2005 | 08:33 AM
Kwicko's Avatar
It's the D16a1 - but I've just been told by jlicrx that it's not as easy as I thought to swap it in there; you DO need the Integra transmission, axles, hubs, and so on (ECU too).
Here's what he clarified for me:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">For the D16A1 into 1st gen Si, you need to use everything from the Integra - engine, transmission, knuckles/hubs, shift linkage and ECU - it does bolt right in - another option is the JDM brown valve cover ZC, which is basically like the D16A1 but has the higher compression pistons and better camshafts - it is about 127hp - check this out:
http://www.redpepperracing.com...ddd40</TD></TR></TABLE>
The reason I said '86 or '87 Integra is because they still used the vacuum advance on the distributor timing; the '88-'89 'Tegs went to an electronic advance. You can still put the '88-'89 engine in your first-gen, but there's a bit more wiring involved, I believe.
Your absolute best source for 1G CRX info is redpepperracing.com. All the first-gen gurus hang out there. It's where I turn to when I need help with my '87 Si...
Sorry for the misinformation on the swap. My bad.
Mike
Old May 20, 2005 | 12:09 PM
hatchinprogress's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold EF &raquo;</TD></TR><TR><TD CLASS="quote">id go ZC turbo.</TD></TR></TABLE> i love my turbo'd zc
Old May 20, 2005 | 12:13 PM
92integra_gs's Avatar
IMO i would scrap that current motor and start out fresh... yea i would try that d16a1....
Old May 21, 2005 | 10:01 AM
shawnCRX's Avatar
yeah idk what i want to do yet...still deciding its a tough decision
2slow2curious
24
Sep 1, 2004 12:10 PM
rsxgirlie
Jan 1, 2003 10:49 AM
T_Rex
Oct 3, 2002 08:45 PM
o0O shyb18 O0o
Aug 31, 2002 09:46 AM
