Bearings? please LOOK
Old May 19, 2005 | 01:07 PM
itr1244's Avatar
Default Bearings? please LOOK
ok when u do engine rebuild.. you need some bearings? where do i get em?
i searched but seriously.. nothing found.
what do i need? crank bearing? and rod bearing? where can i get it
thanks
Old May 19, 2005 | 01:11 PM
Chris N's Avatar
Default Re: Bearings? please LOOK (itr1244)
are you going to rebuild this yourself?
main bearings i would suspect would be a good start.
Old May 19, 2005 | 01:16 PM
Philly_NBP_R's Avatar
Default Re: Bearings? please LOOK (Chris N)
if you're planning on rebuilding the motor yourself, you might want to read this first:
http://www.evans-tuning.com/fo...t=326
Old May 19, 2005 | 01:42 PM
Ausmith's Avatar
There are main and rod bearings. There are 7 different size bearings for the ITR motor, and you can stagger them top and bottom which gives you 49 possible combinations for each journal to get the correct fit.
Old May 19, 2005 | 04:55 PM
itr1244's Avatar
Default Re: Bearings? please LOOK (Ausmith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith &raquo;</TD></TR><TR><TD CLASS="quote">There are main and rod bearings. There are 7 different size bearings for the ITR motor, and you can stagger them top and bottom which gives you 49 possible combinations for each journal to get the correct fit.
wtf's all that ****..
Old May 19, 2005 | 05:03 PM
RTW DC2R's Avatar
this doesnt sound like something a n00b should be doing himself
dont forget the thrust washers
Old May 19, 2005 | 05:04 PM
itr1244's Avatar
the motor will be sent to shop to get it done..
it's my first time doing anything to the motor.. i cant afford to fxxx it up..
the shop should be able to figure those colours right?
but where can i get those bearings?
Old May 19, 2005 | 05:06 PM
RTW DC2R's Avatar
just tell them to get the proper bearings from honda. I would think they could figure out that much. they should know what to get and where to get it. if not, you might wanna take it elsewhere. you shouldnt have to worry about it and scare the rest of us into thinking you are doing this yourself
Old May 19, 2005 | 05:07 PM
KayOs's Avatar
Default Re: (RTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW &raquo;</TD></TR><TR><TD CLASS="quote">this doesnt sound like something a n00b should be doing himself
dont forget the thrust washers</TD></TR></TABLE>
I agree. Consider a professional or friend with vast experience in engine rebuilds. Talk to HT user "Len" for all the parts necessary in your rebuild.
Old May 19, 2005 | 07:40 PM
itr1244's Avatar
Default Re: (RTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW &raquo;</TD></TR><TR><TD CLASS="quote">just tell them to get the proper bearings from honda. I would think they could figure out that much. they should know what to get and where to get it. if not, you might wanna take it elsewhere. you shouldnt have to worry about it and scare the rest of us into thinking you are doing this yourself </TD></TR></TABLE>
lol.. that makes a good sense ... yeah right.. they should know it..
Mugen112
Oct 18, 2006 11:52 AM
killerpenguin21
Jul 12, 2006 07:20 AM
d16dcoe45
Aug 14, 2005 06:21 AM
db2integra
Sep 20, 2004 08:25 PM
