b20 with toda pistons and type r internals
Old May 19, 2005 | 12:32 PM
Twisted driver's Avatar
Default b20 with toda pistons and type r internals
i seen toda pistons that work with b20 block and type r interals my question is how high will this setup rev???
Old May 19, 2005 | 12:36 PM
Default Re: b20 with toda pistons and type r internals (Twisted driver)
i was just wondering cause i am deployed right now and when i come back i was thinking of some builds i would like to try
Old May 19, 2005 | 12:59 PM
97L-esVeeTeg's Avatar
basically your building a 84mm type r block, with really expensive pistons. The rev capabilities will be about the same as a type r, except for the fact that stock b20 are pretty much asscheese
There are many other options for 84-85mm pistons that are more cost effective, if thats a concern of yours, good luck
Old May 19, 2005 | 02:43 PM
Bradstard's Avatar
The Toda pistons for the B20 block are 85mm pistons. Personally, I would not use a stock sleeved B20 block bored to 85mm. Like 97L-esVeeTeg said, there are many better choices for the money that are available in 84mm.
Old May 20, 2005 | 12:45 AM
that was the first time i seen anything like that i am still trying to learn more about the b20 builds what pistons would you recomend for this kind of biuld cause i would like good compression and to rev pritty high but nothing more that the stock type r bottom end can hadle with the torque of the b20
Old May 20, 2005 | 12:56 AM
money will be there when i get back so i will be willing to spend some money in the quest for reliability and quality but if i can find a part that will work just as good but not cost an arm and a leg i would rather go with that cause i dont make that much money to be throwing it into the name on the part as a good freind of mine would say "GO FAST OR S#CK" i dont care who make the part just as long as it makes me faster
monster_c
May 25, 2012 12:10 PM
jdmdikk
Dec 4, 2008 01:01 PM
JDM97EK
14
Mar 7, 2006 07:44 PM
jdm92teg
Nov 11, 2004 09:12 AM
