sohc obx/quaife lsd, need help
Old May 19, 2005 | 12:14 PM
DaZman69's Avatar
Default sohc obx/quaife lsd, need help
ok, i ordered a sohc obx lsd. model number lsd9200. I talked to both obx and tuningdepot (ebay store), and both said i had the correct lsd. Yet my lsd accepts 40mm bearings, and my stock diff (s20 tranny off d16z6) uses 35mm bearings.
When you guys installed your lsd's, either quiaffe or obx, you just used the stock bearings correct??? theres no special sized bearings or anything? or am i just fucked
Old May 24, 2005 | 03:02 PM
the jdmchop's Avatar
Default Re: sohc obx/quaife lsd, need help (DaZman69)
bump i would like to know also
Old May 24, 2005 | 04:27 PM
earl's Avatar
With the D series, you always need to know if your tranny is a 40mm or 35mm. If obx only make a 40, then you are screwed for your 35 tranny.
BTW, there is no way I know of that ANYONE could tell you which tranny you had, so whoever told you the 40 was right for you, was just trying to make a sale.
Old May 24, 2005 | 05:13 PM
DaZman69's Avatar
Default Re: sohc obx/quaife lsd, need help (earl)
i was under the impression that all ex's/si's had 40mm bearings
the vx/dx/ had 35mm bearings. I just figured i had a vx tranny on my car by accident all this time. It had a p20/a0000 on my 35mm tranny, and a p20/b0000 on my extra 40mm tranny
so your saying that some ex trannies with the same gearing have different differential bearing sizes?
Old May 24, 2005 | 07:05 PM
turbo95eg6's Avatar
the ex tranny uses 40mm bearings...so are you saying you didnt have a z6 tranny...?
Old May 25, 2005 | 01:03 PM
DaZman69's Avatar
Default Re: sohc obx/quaife lsd, need help (turbo95eg6)
it said p20/a0000, and it had 35mm bearings, it came off my ex. But I had got a new tranny put on several years ago by a shop. I guess they gave me the wrong one.
I had one that came off an si in my garage with 40mm bearings, it said p20/b0000
but sounds like earl is trying to say an ex tranny can be both
Old May 25, 2005 | 01:17 PM
racinskittle's Avatar
**** obx......Their customer service is horrible. Someone needs to give those guys there a wake-up call. They make no effort to help their customers. I wish someone would just firebomb that place.
Old May 25, 2005 | 04:18 PM
JFK78's Avatar
ALL si/ex trannys are p20/b0000 and have 40mm bearings.
There is no such thing as a 35mm bearing ex/si tranny. Sounds like the shop that swapped your tranny screwed you. Didn't you notice any difference in the new tranny they put in?
It is also possible that someone put all the ex/si gear ratios and final drive into your 35mm bearing p20/a0000 tranny case, but that would be a pretty stupid thing to do.
Old May 25, 2005 | 11:09 PM
DaZman69's Avatar
Default Re: sohc obx/quaife lsd, need help (JFK78)
nope, it was a long time ago, i was 18, i didnt notice a difference.
Old May 27, 2005 | 07:09 PM
Mista Bone's Avatar
D Tranny Guru
hang on there before you go screwing up MORE info...........
90-91 EX sedans are 35mm, which Quaife used and fucked up all the info for the last 10+ years!
PL3/P20/P4L, it doesn't matter.........
A000 or A100 = 35mm bearings
B000/3000/6000/9000 = 40mm bearings
I cracked the code, I know.
Now you get a 88-89 tranny like this.............
have no fear, just pull a axle...........
35mm, notice the thinner axle tube........
40mm, thicker axle tube.......
looking though on a 40mm..............
Old Jun 1, 2005 | 02:20 PM
Gearspeed-Performance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JFK78 &raquo;</TD></TR><TR><TD CLASS="quote">
There is no such thing as a 35mm bearing ex/si tranny. .</TD></TR></TABLE>
What about the good ol' 89 CRX si that had 35mm bearings?
Old Jun 1, 2005 | 09:49 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: sohc obx/quaife lsd, need help (GearSpeedEF9)
EVERY 88-91 Si tranny I've tore apart has been 40mm.
team 15
Jun 4, 2007 12:56 PM
miyagi
Apr 20, 2006 11:55 AM
onegreedy
Jan 17, 2006 03:23 PM
civicgsr93
May 14, 2002 09:41 AM
