Pistons, valves, and spark plugs looks funny... can somebody chime in!!!!!
Well this is a ls/vtec setup just pulled the head off because we're putting another vtec head on and to find out the valves, pistons, and spark plugs are brownish... can anybody explain whats the cause???
TIA
-dara
TIA
-dara
thats one nasty build up.... have u tried cleaning it and see how bad it is stained??
i doubt its burning oil.... as the chambers are does not seem to have oil or "gunky"
residue...
use carb cleaner and then follow it up with some wd40
residue...
Someone took a **** in your intake? The stains on the pistons looks like rust, but it can't be possible.
It looks like your head gasket was shot and it was burning coolent and it looks like water was more in the cooling system than radiator fluid thats just my guess
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9Greg »</TD></TR><TR><TD CLASS="quote">It looks like your head gasket was shot and it was burning coolent and it looks like water was more in the cooling system than radiator fluid thats just my guess</TD></TR></TABLE>
found the problem not a big dilly it all cleaned off it was from additives
I agree with that, thats the only way rust can build up like that is from water/coolant getting into that area via a headgasket being gone. Glad to hear you got it cleaned up, dont forget to get a new headgasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreStaged12s »</TD></TR><TR><TD CLASS="quote">
headgasket was never shot, compression test was 220 all the way no leaks, no oil&coolant mixture
</TD></TR></TABLE>headgasket was never shot, compression test was 220 all the way no leaks, no oil&coolant mixture
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skank_aSS_Dara »</TD></TR><TR><TD CLASS="quote">
headgasket was never shot, compression test was 220 all the way no leaks, no oil&coolant mixture</TD></TR></TABLE>
It doesnt have to be shot all at once, it could have been something from over time, there doesnt necessairly have to be a oil/coolant mixture for a 1000 miles, how many miles does the motor have?
I was going to say it looks like the result of the fuel you are burning.. I can tell you one thing from those pics. It looks like you were running that engine WAY too rich
i concur!
i take back my concuration... i read further
i concur!
Skank_aSS_Dara
May 20, 2005 01:10 PM
