mini me problems!
Old May 19, 2005 | 10:46 AM
my car sucks84's Avatar
Default mini me problems!
I just swapped a y8 head on my a6 block. i kept the a6 intake manifold, and exhaust manifold on as well. it has a chipped pm6 for 1 wire vtec, and z6 fuel maps. when im driving the car runs fine, but when i put in neutral and coast to a stop....it dies. it will start right back up, but it does it everytime i stop. i can give it gas right when its about to die and it wont cut off. any idea why this is happening?
ive switched dizzys with my friend and its still doing it, so i dont think its that. we have also checked the timing and its good too. any help would be appreciated. thanks in advance guys
Old May 19, 2005 | 10:48 AM
Brownjd's Avatar
Default Re: mini me problems! (my car sucks84)
does it idle when you start it? if it doesn't idle at all, adjust your idle screw
Old May 19, 2005 | 10:51 AM
right when i start it, it idles fine....and after it dies and i have to start it again it idles fine, it only dies when i put it in neutral and im coasting to a stop. any ideas?
Old May 19, 2005 | 11:14 AM
Brownjd's Avatar
start your car and push on the brakes a few times. since it only happens when your stopping (aka braking) maybe something to do with the brake booster?
see if you can make it die by pressing on the brakes a few times or holding them down
Old May 19, 2005 | 11:51 AM
90 Si Hatch's Avatar
Default Re: mini me problems! (Brownjd)
Sorry but this has nothing to do with why ur car is cutting off. But i just wanted to know how you have you v-tec coming in???
Old May 19, 2005 | 01:23 PM
Default Re: mini me problems! (90 Si Hatch)
i got someone on dragva to chip an ecu for me with z6 fuel maps, and 1 wire vtec. i just run 1 wire from an empty spot on one of the ecu plugs to the vtec solenoid. vtec kicks in at 4800rpm.
when i let it idle and push the brakes, the idle goes up a little bit then back to normal. any more ideas?
Old May 19, 2005 | 05:34 PM
nobody knows?
Old May 19, 2005 | 05:53 PM
d357r0y's Avatar
Oddly enough I had this same problem when I did my swap.. then it just "went away".
I know that doesn't help right now but maybe it puts some light of hope at the end of the tunnel
Old May 19, 2005 | 06:57 PM
Default Re: mini me problems! (d357r0y)
there is no light!!!! my car wont start now! i have an aem short ram intake and i think it was touching the positive battery cable, so i wrapped electrical tape around the part that was touching it, and it started right up. then i went to the store and it kept dieing! now it wont start and every time i tried to start it, it sounded weaker and weaker..... im gettin tired of messin with it!
Old May 20, 2005 | 07:13 AM
Old May 20, 2005 | 07:18 AM
2kTeg's Avatar
jump it see if that starts it, you should adjust the idle screw maybe when its cold it idles high enough to stay on and when you warm the car up it comes down to op temp and the idle is to low to keep the car on... just a thought
its gatta be vacuume
Old May 20, 2005 | 07:33 AM
Default Re: mini me problems! (2kTeg)
ill try adjusting that today if i can get it running. is it not a good idea to have an a6 intake mani on a y8 head?
Old May 20, 2005 | 12:31 PM
i also have a stock 92-95 fpr also, i read that i needed it for the mini me swap. dunno if that really makes a difference tho. i still need help guys!!!!!
Old May 21, 2005 | 06:53 AM
help!
rollinhonda3
Nov 13, 2010 09:53 AM
mjrino
May 16, 2007 04:28 PM
teg racer 877
May 23, 2006 08:03 PM
civicmug
11
Aug 23, 2004 10:48 PM
