Battery Problems? 3 new batteries in 6 months?!?
Old May 19, 2005 | 10:15 AM
Savv's Avatar
Default Battery Problems? 3 new batteries in 6 months?!?
When i first got my teg it had a battery with about 700CCA in it. It died about a year later. I went to Napa all they had are 550CCA. So I did that, now this is my third batery in 6 months. The first one died and the second one expanded and leaked and burnt a hole in my evap canister and this one is OK but I need to do something before it goes bad or starts leaking.
Any help???
Old May 19, 2005 | 11:11 AM
pushinlsteg's Avatar
Default Re: Battery Problems? 3 new batteries in 6 months?!? (Wild0ne21)
theres a short somewhere, or something is drawing from the battery all the time...something really small and insignificant except after a long time, sucks ***, good luck finding it **** like that is so annoying.
I would start with...checking lights and stuff maybe the light in the glove box or in the hatch if you have one or .... something dumb like your stereo
Old May 19, 2005 | 12:58 PM
BlackDAy's Avatar
Default Re: Battery Problems? 3 new batteries in 6 months?!? (pushinlsteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pushinlsteg &raquo;</TD></TR><TR><TD CLASS="quote">theres a short somewhere, or something is drawing from the battery all the time...something really small and insignificant except after a long time, sucks ***, good luck finding it **** like that is so annoying.
Word.
Old May 19, 2005 | 01:56 PM
Deluzional's Avatar
Default Re: Battery Problems? 3 new batteries in 6 months?!? (BlackDAy)
I have a similar problem, I go through 1 battery a year. I have no idea what the problem is either, thought it was my alternator but it still read 12volts
Old May 19, 2005 | 02:39 PM
Savv's Avatar
Default Re: Battery Problems? 3 new batteries in 6 months?!? (Deluzional)
I have a stero hooked up but I never had a problem before, I have checked everything, like lights because I thought that would be the problem
but it doesn't explain why the third battery swelled and overflowed....is it possible that I need a bigger batter like another 700cca?
Old May 19, 2005 | 05:30 PM
NeoGSR's Avatar
maybe with a smaller battery it's over-drawing and causing the battery to heat up and swell....
i gotta NAPA battery and it's been trouble free for 2 years now....bout the only thing that NAPA has that's worth a ****....
Old May 20, 2005 | 09:59 AM
Savv's Avatar
Default Re: Battery Problems? 3 new batteries in 6 months?!? (NeoGSR)
i guess I wil look for a bigger battery and maybe test the altenator
Old May 20, 2005 | 12:35 PM
Medek's Avatar
I used to dump batterys every year also. I also have a system, My mech. suggested a "deep cycle" so i wouldnt have the starting problems and voltage losses. I went with the Optima Yellow Top, but I had to move it into the trunk. I've never been happier. And it's been trouble free for 3 years now. Love that battery.
Old May 20, 2005 | 05:35 PM
TurboGS-R's Avatar
Default Re: Battery Problems? 3 new batteries in 6 months?!? (Medek)
I have a similar problem...
My battery (Optima yellow) died 2 times, so I got a Diehard now and always unplug the negative when I go somewhere and take the battery in for the night.
I'm not gonna let it just keep draining batteries.
Old May 23, 2005 | 11:44 AM
Medek's Avatar
Default Re: Battery Problems? 3 new batteries in 6 months?!? (TurboGS-R)
Sounds like you have a short or a constant wired up without an ignition on & off. faulty wiring would keep your accessories on after you turn off the car.
Old May 23, 2005 | 12:13 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
could be an alternator problem. To check it get a voltage testor, and with the car running put the electrodes on the +/- sides of the battery. A good alternator will put out about 14v, while a good battery (with the car off) will be 12v.
EDIT: Oh i forgot to add that autozone has a machine that will check out your entire charging system, and its free! Maybe u should just take it there
Old May 23, 2005 | 04:43 PM
TurboGS-R's Avatar
Default Re: Battery Problems? 3 new batteries in 6 months?!? (rukawa1one)
I had my alternator, etc. checked at Kragen, so I know it's a "short" somewhere in the system especially because a "ghetto shop" hooked up my ****. I just don't have the money and time to check that right now.
Old May 23, 2005 | 06:54 PM
Demented's Avatar
yup you have too high of a load on your battery when the car is off. A good way to troubleshoot that is with a voltmeter on the amps setting. Put the meter inline with the battery, check the load with everything closed (doors, domelights...etc) Then start unpluging suspectable things (radio, alarm, both unlikely but possible, domelights..etc) unplug fuses, once you see the meter go down you may have found it.
Pm for more details
dirtyharryhatch
21
Aug 26, 2008 07:15 PM
thehatchninja
Apr 1, 2004 03:10 PM
Trooper
Audio / Security / Video
Sep 25, 2003 05:26 AM
LudemanDan
Aug 29, 2003 07:53 PM
nwdave
Aug 28, 2003 11:11 PM
