swapping over integra brakes to ek hatch couple of questions
Old May 19, 2005 | 10:13 AM
Nextelbuddy's Avatar
Default swapping over integra brakes to ek hatch couple of questions
ok i have searhced but i dont see the answer to my questions..
lets say i have a integra with 5 lug integra brakes..and a ek hatch next to it with gsr brakes.. i need to swap the 5 lug onto the ek hatch and the gsr brakes onto the integra...
i was thinking for the fronts just removing the 5 lug spindle leaving the upper and lower control arms on teh integra ... then on the civic do the same thing just swapping sindles but leaving the upper and lower control arms...
now for the rear just swap trailing arms and hubs but leave the rear LCAs on each car...meaning i leave the integra LCA on teh integra and same for the civic leave its LCAs on there as well...
does that sound ok? or is there anythign im mising?
Old May 19, 2005 | 10:33 AM
cruizinmax's Avatar
Thats all you need to do. You cant swap (front or rear) lower control arm anyways they wont work.
Old May 19, 2005 | 10:37 AM
Default Re: (cruizinmax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cruizinmax &raquo;</TD></TR><TR><TD CLASS="quote">Thats all you need to do. You cant swap (front or rear) lower control arm anyways they wont work.</TD></TR></TABLE>
ok i got ya.. so bascialyl do NOT remove any of the LCAs on the front or rear of both cars just remove spindles and rear trailing arms and everythign should swap over fine and maitain proper geometry...
Old May 19, 2005 | 12:18 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Nextelbuddy)
Old May 19, 2005 | 01:15 PM
Default Re: (94eg!)
one last thing.. theres one piece im not sure of.. the piece that is on top of the trailing arm that controls camber.. has 2 bolts that thread into the chassis... do i leave those on the car or leave them atached to the trailing arms and swap over to new car?
Old May 19, 2005 | 01:21 PM
94eg!'s Avatar
#1 Super Guy
Loved
That's the upper control arm. You should just leave the Upper control arms, Lower control arms, shocks, and compensator arms (small arms at the nose of the trailing arms) all attached to the chassis. Then you only have to position the Trailing arms (*super easy*)...
Old May 19, 2005 | 01:28 PM
Default Re: (94eg!)
ok got yea thats awesome bro thanx
Old May 19, 2005 | 06:31 PM
just thought of one thing.. will my 1994 integra E brake cables work in a EK hatch?? or wil they be too long or short??
Old May 26, 2005 | 08:09 AM
cruizinmax's Avatar
They will work. I have them in my car. One of the hangers won't line up but it doesn't affect anything.
GSR_Hatch8
Mar 4, 2008 08:34 AM
jdub db8
Oct 22, 2004 07:35 PM
atc5
Aug 9, 2004 06:30 PM
S2KP
Jun 26, 2004 01:56 AM
ncVTEC1313
Jun 3, 2004 05:14 PM
