ITR Rotor Button Screw
Old May 19, 2005 | 10:07 AM
Bradstard's Avatar
Default ITR Rotor Button Screw
Does anyone know the part number for this screw? I was a dumb *** and had too many beers last night while changing my rotor button and lost the screw. I went by Honda and picked up a rotor button for a 2000 Civic Si but the screw looks to be longer than the ITR one. (Honda parts was on the way to where I was going) Are these the same part number? I tried searching but did not find the part number. Thanks!
Old May 19, 2005 | 10:23 AM
ebelp's Avatar
Default Re: ITR Rotor Button Screw (Fat Bradstard)
30135-P73-004
Pretty sure it's the same as the Si's screw. Did you try putting it in and seeing if it holds it securly?
Old May 19, 2005 | 10:57 AM
R you serious's Avatar
dam those screws to hell.
first thing i did was throw them all away
Old May 19, 2005 | 10:59 AM
typer_801's Avatar
Default Re: ITR Rotor Button Screw (ebelp)
Cross reference at http://www.SLHondaparts.com
http://www.slhondaparts.com/br...=true
93600-06014-0H
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">30135-P73-004
Pretty sure it's the same as the Si's screw. Did you try putting it in and seeing if it holds it securly?</TD></TR></TABLE>
Old May 19, 2005 | 11:40 AM
FormulaGSR's Avatar
you know you dont need those right?
Old May 19, 2005 | 12:11 PM
.RJ's Avatar
.RJ
loctite is your friend... just a reminder. I do know the gsr and itr parts are the same.
Old May 19, 2005 | 12:48 PM
Bbasso's Avatar
Chuck it!!! really.
Old May 19, 2005 | 02:38 PM
IVI's Avatar
IVI
Default Re: ITR Rotor Button Screw (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Chuck it!!! really. </TD></TR></TABLE>
they're put on at factory, other than that you dont need them once you remove it.
Old May 19, 2005 | 03:29 PM
JDMitr54's Avatar
Default Re: ITR Rotor Button Screw (IVI)
toss it..
Old May 19, 2005 | 05:37 PM
JDM Factor's Avatar
for the assembly line only
Old May 19, 2005 | 05:49 PM
Chris F's Avatar
Default Re: (JDM Factor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_801 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.slhondaparts.com/br...=true
93600-06014-0H</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">dam those screws to hell.
first thing i did was throw them all away </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote">you know you dont need those right?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">they're put on at factory, other than that you dont need them once you remove it.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">for the assembly line only</TD></TR></TABLE>
Are j00s talking about the rotor screws on the BRAKE rotors,
or the screw on the rotor button inside the DISTRIBUTOR??????
Is there a screw on the rotor button in the distributor? Is it just part of the cap? That's the only rotor button that I know of on a car.
-Chris
Old May 19, 2005 | 05:52 PM
Chris F's Avatar
Rotor button: (not honda)
Old May 19, 2005 | 05:54 PM
FormulaGSR's Avatar
Default Re: ITR Rotor Button Screw (Chris F)
i thought he ment the screw on the rotors but you may be right. If so disregaurd my statement
Old May 19, 2005 | 05:58 PM
RTW DC2R's Avatar
Im confused.
Old May 19, 2005 | 05:59 PM
Chris F's Avatar
Default Re: (RTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW &raquo;</TD></TR><TR><TD CLASS="quote">Im confused. </TD></TR></TABLE>
Me too! Damn me! Anyone have a pic of the inside of the distributor cap? Any screws on the cap near the rotor button?
Old May 19, 2005 | 06:25 PM
B2FiNiTY's Avatar
Default Re: (Chris F)
Sounds like he is talking about the distributer rotor.
Old May 19, 2005 | 06:43 PM
mugenracer's Avatar
Default Re: (B2FiNiTY)
Does he mean the little screw that holds the rotor in place or something else...i'm confused too
Old May 19, 2005 | 08:02 PM
Black R's Avatar
25 Year Member
.....he said "rotor button" which means in the distributor.
Call Len you big dummy!
Old May 19, 2005 | 10:59 PM
eK9aT10pSi's Avatar
i thought the pin in the center cannot be changed? or can it?
Old May 19, 2005 | 11:05 PM
KayOs's Avatar
Default Re: ITR Rotor Button Screw (eK9aT10pSi)
The pic clearly is labeled "Not Honda"
Old May 20, 2005 | 03:57 AM
Opie's Avatar
This screw?
That did this?
This one? Well F that screw!
Old May 20, 2005 | 04:34 AM
Chris F's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">This screw?
That did this?
Hey dopie, what am I looking at here? I can't make it out.
Old May 20, 2005 | 04:54 AM
Bradstard's Avatar
Default Re: (opie)
Yep, that one. The Civic Si one is too long. I'm going to try to find one local so I can drive the car to the ATL BBQ meet tomorrow.
Old May 20, 2005 | 04:59 AM
Chris F's Avatar
Default Re: (Fat Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, that one. The Civic Si one is too long. I'm going to try to find one local so I can drive the car to the ATL BBQ meet tomorrow.</TD></TR></TABLE>
You bradstard! That's not a rotor button screw!
011 30135-P73-004 SCREW-WASHER (5X12) 1 1998 INTEGRA 2.02 1.61
Distributor rotor screw, maybe. Not rotor button though.
At least the controversy is solved!! Hahahaha another H-T drama unfolds..
Old May 20, 2005 | 07:01 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
At least the controversy is solved!! Hahahaha another H-T drama unfolds..</TD></TR></TABLE>
It may be a misnomer, but 99.999999999% of us call it the rotor button screw...
