blowing fuses, i'm stumped
Old May 19, 2005 | 09:04 AM
jbscivichb92's Avatar
Default blowing fuses, i'm stumped
the car: 88 civic hb dx
i turn the key the the on position without starting it and i blow a fuse. i'm not sure which one it is. its under hood. if you're faceing the engine bay standing next to the passenger side fender its all the way to the left second from the top. i'm pretty sure it controls the fuel pump because when i put the car in on the fuel pump doesn't prime. i've checked the whole wire harness and nothing is grounding out. any help would be greatly appreciated.
Old May 19, 2005 | 09:13 AM
RCautoworks's Avatar
Default Re: blowing fuses, i'm stumped (jbscivichb92)
Find out what fuse it is, more then likely there is a short in the wire that is grounding out.
Old May 19, 2005 | 09:16 AM
menappi's Avatar
maybe u have the wrong size fuse? good luck. it happened out of no where? did you do any wiring in any other part of the car?
Old May 19, 2005 | 09:19 AM
Default Re: (menappi)
i pulled out the old d15 and put in another one.
latino honda
May 24, 2019 11:32 AM
07fiit
Honda Fit
15
May 28, 2016 02:37 AM
austinwasthere
Nov 26, 2013 04:28 AM
93eg1
14
Oct 26, 2010 03:36 PM
