Bad oil leak??
Old May 19, 2005 | 07:55 AM
prelude1897's Avatar
Default Bad oil leak??
I'm having a bad oil leak now, and it all just started when I was driving last night. At first, it was a real slow leak, but nothing major until last night. I was smelling oil and saw alot of smoke in my mirror. I got home, popped my hood and noticed alot of oil on the driverside near the back of the motor. Does anyone know if there are oil lines or something on the driverside? Is there a gasket between the head and block? Is there anything else that could possibly be wrong on the driverside block? Are 5th Gen Preludes known to have a possible oil leak coming from around that side? Also, I have about 117K miles on the motor.
Old May 19, 2005 | 08:14 AM
95PreludeSi's Avatar
Default Re: Bad oil leak?? (prelude1897)
There was that recall on most F & H series motor due to the balance shaft seal coming out. Might want to check into that area.
Old May 19, 2005 | 08:32 AM
Default Re: Bad oil leak?? (95PreludeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi &raquo;</TD></TR><TR><TD CLASS="quote">There was that recall on most F & H series motor due to the balance shaft seal coming out. Might want to check into that area.</TD></TR></TABLE>
My car has a salvage title, do you think they'd still replace it?
Old May 19, 2005 | 08:45 AM
I just called Honda, and they said the recall expired 2 years ago
Old May 19, 2005 | 09:07 AM
CarpAngler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">I just called Honda, and they said the recall expired 2 years ago</TD></TR></TABLE>
That would be correct but you should call them back because they will be able to tell you if the recall was ever done on your car.
Old May 19, 2005 | 09:24 AM
98TypeSH's Avatar
Default Re: Bad oil leak?? (Lude_97)
how does a recall expire if its a recall ? check the lower timing cover. does it have a poopload of oil in it ?
Old May 19, 2005 | 09:29 AM
gutterslide's Avatar
Default Re: Bad oil leak?? (98TypeSH)
a friend's accord recently had a horrendous leak from the oil pressure sending unit, above the oil filter. i don't think that's a common place for a leak, but there aren't many places on the back of the block that can leak, really.
Old May 19, 2005 | 09:30 AM
ThE PiMpiN Co's Avatar
check the cam seals. i had an integra and i blew out the cam seals and my headgasket and there was white smoke coming out of it and oil on the driverside back area of the block. clean up the oil and then try to see where its leaking from
Old May 19, 2005 | 09:37 AM
Default Re: Bad oil leak?? (gotb18)
Thanks alot. I found the problem. I was missing one of the oil bolts. Its sits right beside your VIN number. I went to my GF's, dads salvage yard, and luckly he had a couple of Preludes there, so I was able to figure out what it was. Thanks again guys for all the help
Modified by prelude1897 at 1:45 PM 5/19/2005
ender214
Feb 24, 2008 02:32 AM
92redhatch
Aug 27, 2006 09:52 AM
danteisme
Jun 1, 2005 05:31 PM
wootcivic
Apr 1, 2005 11:54 AM
