DASH BOARD REPLACEMENT...VIN NUMBER???
Old May 19, 2005 | 07:16 AM
mr. vang's Avatar
Default DASH BOARD REPLACEMENT...VIN NUMBER???
okay just picked up a new(used) dash board cause mines had cracks in it..when replacing it what do u guys do about the vin..should i replace the vin number with mines..what do i do..???thanks for the help guys..
Old May 19, 2005 | 10:37 AM
Kataku2K3's Avatar
Default Re: DASH BOARD REPLACEMENT...VIN NUMBER??? (jdm_whore)
Most of the time we do (ya know, particularly with those ED/EH chassis, when you've got that blue dash and you swap it for a black one... lol), and it's easy enough so why not. I've ****'d up a few VINs before, slipping with the drill while removing the rivets, and so not moved the original over and it's never been a problem. Just take your time, carefully drill the rivets out, the pop some new ones in... you should be fine.
Old May 20, 2005 | 10:12 PM
Quad-Damag's Avatar
Default Re: DASH BOARD REPLACEMENT...VIN NUMBER??? (Kataku2K3)
It's a problem, i got my car impounded over it
use a RIVIT Gun and make it look like it's stock and make sure u put the VIN the right way
Old May 21, 2005 | 12:47 PM
JDMworld's Avatar
place a couple layers of duct tape on top of the vin before you drill it out.... this way if you slip theres still chance of the vin surviving.
Old May 23, 2005 | 06:59 PM
DSRxSALSA's Avatar
Default Re: DASH BOARD REPLACEMENT...VIN NUMBER??? (Quad-Damge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge &raquo;</TD></TR><TR><TD CLASS="quote">It's a problem, i got my car impounded over it
use a RIVIT Gun and make it look like it's stock and make sure u put the VIN the right way</TD></TR></TABLE>
i heard about this .. =x dang
Old May 26, 2005 | 09:06 AM
mr. vang's Avatar
thanks alot guys...
Old May 26, 2005 | 09:59 AM
DC2 to AP2's Avatar
this is what i did and it came out perfect and i even used the original rivet.
your dash - cut little slots on the dash with a dremel and slide it out.
new dash - drill the the rivets out and just slightly enlarge the 2 vin holes.
now all you need to do is push your vin in and it will fit snuggly. it will look stock and no one can tell. good luck.
Old Jun 10, 2005 | 08:41 AM
Tuan's Avatar
Default Re: DASH BOARD REPLACEMENT...VIN NUMBER??? (imola-red dc2)
CAn you order new VIN tags? from ACura or Honda?
Old Jun 10, 2005 | 08:49 AM
dustin's Avatar
I just drilled out the old one and riveted it to the new dash. Took a few minutes and I didn't even think twice about it... heh.
Old Jun 10, 2005 | 05:14 PM
phatrick2332's Avatar
Ive got mine in the glove box with the insurance and registration incase anyone gets picky lol
Old Jun 11, 2005 | 03:43 AM
granturismonut's Avatar
Default Re: (phatrick2332)
If your gonna drill, drill from the back, and enlarge the holes in the new dash and use some adhesive to keep it there. Or you can just use the correct gun to do the job too
Old Jun 11, 2005 | 12:59 PM
90REDHATCH's Avatar
I am a scammer!
Default Re: (granturismonut)
just take your time patience is quality and it will come out nice drill the rivets and rivet it back on then no hassles from the police
Old Jun 13, 2005 | 04:12 PM
XxRONNxX's Avatar
New User
I used a dremel to cut part of the rivits off the back. The old rivits slid right off the front....didn't even scratch the VIN plate. Then I used a regular rivit gun and rivits from Home Depot. Looks just like it came from the factory. You have to have the dash off of course.
hondachris1994
Sep 24, 2010 12:11 PM
snake_eyes
Nov 17, 2009 10:52 PM
jrzy2nR
Aug 19, 2009 10:12 PM
lmike6453
Feb 13, 2008 06:23 PM
apm
Nov 17, 2005 10:19 AM
