h23a head swap to f22a1 block
Old May 19, 2005 | 06:53 AM
CB7DOHC's Avatar
Default h23a head swap to f22a1 block
Im pretty definiate its an easy swap from researching but i keep coming up short on actual swap info... if i was just to purchase the head or long block would it bolt perfectly onto my f22a1 block? any additional parts? total $$$ figures? and if not whats the easiest/cheapest way to DOHC my 91 5spd coupe
Old May 19, 2005 | 08:08 AM
90accorddx's Avatar
Default Re: h23a head swap to f22a1 block (91crxb16a)
there will probably be some need to be some machine work for the head bolts but dont quote me on that
Old May 19, 2005 | 10:09 AM
CB7DOHC's Avatar
any more inputs??? at first thought most people assume it may need machine work b/c they're thinkin of the h22a which has two small VTEC oil drain holes but the h23a does not...is that what u meant by needing machine work?
Old May 19, 2005 | 10:11 AM
CB7DOHC's Avatar
a few more questions would be, what timing belt will i need? or all timing belts for that matter? if im remembering correctly i saw a picture of the f22 head gasket placed over the h23a head and everything matched up perfectly.
CB7DOHC's Avatar
any advice,pictures,informations,prices, anything related to this swap is greatly appreciated and need kinda quickly
Old May 19, 2005 | 10:56 AM
90accorddx's Avatar
Default Re: (91crxb16a)
Really im not sure there should be plenty on this subject on here if you search ive never actually heard of this swap just the IM from the h23 to the f22 but im guessing you have to use the timing belt from the h23 because it would have to be longer to clear the two cams opposed to just the one
Old May 19, 2005 | 12:18 PM
THEROPE's Avatar
Default Re: (90accorddx)
you are in over your head if you think this will be a stright forward swap
there is only 3 ppl i know of on this board that have done the g23 head swap and let me tell you from reading all 3 of there threads word for word its alot of work
THEROPE's Avatar
but if you you want to do it read here
https://honda-tech.com/zerothread?id=1069869
Old May 20, 2005 | 05:55 AM
CB7DOHC's Avatar
Default Re: h23a head swap to f22a1 block (THEROPE)
if it was a straight forward swap id be all for it but if not ill look into something else, im at school right now so cant really get into reading that whole tutorial...any idea if the f22b will swap directly into my motor mounts and all the hoses will connect right up? Im just looking to replace my 200000+ mile f22a1 with something a lil different and definantly more power but not as expensive as the h22 so im leaning towards the f22b DOHC non-vtec
TheRookie74
Sep 7, 2014 09:59 PM
GTibunny16v
Dec 20, 2005 08:24 PM
Swap_File
Dec 11, 2005 11:51 PM
biggnubbs
Nov 2, 2005 09:38 AM
integral94
Jun 2, 2004 08:33 PM
