Search may be down. Looking for ideas on heat shield for J's intake
as the title says. I tried searching for just "J's Racing" in the archived content withing the ITR fourm with no results so search may be down. I'm looking for pics of people with DIY heat sheild for the J's racing intake. TIA
Are you running one with ABS or without? With the abs version its slightly harder. Its not hard to make a box. Get some thin sheet metal > bend and cut to the size you need > rivet box togehter > add some foam around the top so the box touches the hood when shut.
I was suppose to build one last weekend but I got busy. Perhaps I'll do one this weekend and post it up for all to see
I was thinking about an aluminum box covering only the filter with a rubber ring that goes around the intake tubing and is open on the bottom of the box and covered on all other sides. Any of you see a problem with this?
I bought (i'm embarressed to say) an APC heat shield....BUT its the only one that i found that shields 75% of the filter and the back of it in enclosed unlike those POS shields you see on ebay. I have the open section facing towards the radiator and i know that when the fan is on, hot air is directed towards the filter, but turning the shield to block that air also blocks air from my cold air feed.
