need help on Ls/Vtec
Old May 19, 2005 | 12:00 AM
gamakichi77's Avatar
Default need help on Ls/Vtec
rite now i'd just bought an B18B blocks. But i'd already purchased an CTR pistons....mostly people advise me on getting an P30's which will give me more CR on my engine....
and if i'm still stick to use an CTR pistons, how can i reduce or diminished knocking issue? ...........
Old May 19, 2005 | 11:40 PM
anyboy?
Old May 20, 2005 | 07:34 AM
mmuller's Avatar
Mad Scientist
Default Re: (acidburns_di)
mmm, use a thicker HG; enlarge the combustion chamber.
Old May 20, 2005 | 10:33 PM
mtber's Avatar
Default Re: need help on Ls/Vtec (acidburns_di)
Proper fuel & ignition tuning is the key
Old May 20, 2005 | 11:39 PM
Combustion Contraption's Avatar
Fly cut the valve releifs for more clearance to play with cam timing. Youll lose a tiny bit of static compression, but youll be able to play with your cam timing more, enabling you to shift dynamic compression around and help ward off knock.
Errol
Aug 16, 2004 09:22 AM
WhoNeedsBoost
Feb 26, 2004 07:10 PM
JLange
Aug 9, 2003 08:56 AM
ID_ten_T
Jun 15, 2003 04:14 PM
Civic DX 4dr
Nov 4, 2001 11:55 AM
