question:can you mate an OBD1 b18b with a cable b18a tranny?
Old May 18, 2005 | 10:27 PM
redDAinteg's Avatar
Default question:can you mate an OBD1 b18b with a cable b18a tranny?
ok cause im really deciding on going turbo now, because why spend all the money on going GSR or LS/vtec when I can spend equal to less and be much much faster with an LS-turbo. well I have a 160,xxx mile b18a in my 92 teg and I'm thinking that an old motor shouldnt be boosted when it has such high mileage already sooo I was thinking about swapping a 94-95 OBD1 LS long block into my 92 DA.this way I wouldnt have to deal with OBD2 to OBD1 conversion, and the motor will have low low low mileage. but my question is can the 94-95 b18b be mated to the cable tranny thats already in my DA ? if yes then its just a direct bolt on right? or what should I encounter also ? I know alot of you will tell me to search and I have and found alot of what i needed to know but i didnt find a topic on this question. thanks.
Old May 18, 2005 | 10:42 PM
Korch94's Avatar
Default Re: question:can you mate an OBD1 b18b with a cable b18a tranny? (redDAinteg)
all of the b-series trannys will fit to all of the b-series blocks (disregarding the early prelude b20a motor which is not the same)
if you want another b18a/b bottom end then you can use one from any year without a prob.....even one from an obd2 car.....it makes no diff what so ever.
Old May 18, 2005 | 10:46 PM
phatnucca's Avatar
Yes.. the B18A tranny will bolt right up.. no problems
Old May 19, 2005 | 01:57 AM
redDAinteg's Avatar
Default Re: (phatnucca)
so the b18b longblock obd1 will bolt right up to the cable tranny of the b18a no problems right ?
Old May 19, 2005 | 08:07 AM
Korch94's Avatar
Default Re: (redDAinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">so the b18b longblock obd1 will bolt right up to the cable tranny of the b18a no problems right ?</TD></TR></TABLE>
correct
Old May 19, 2005 | 09:26 AM
AIminiS10's Avatar
Default Re: (Korch94)
Since you said a 92 it will bolt up without a problem. If it was a 90 or 91, you would have to keep the flywheel off of the B18A because the input shaft is different size, but since it is a 92, the input shaft is the same size. Everything will line up nice and bump for a fellow LS-t!!
Fallen86
Feb 6, 2006 11:18 PM
B16Civic93
Jun 2, 2005 04:12 AM
CRXRTYPE
Aug 5, 2004 01:02 PM
crxjake
Jun 18, 2003 05:07 AM
efvader
16
May 21, 2002 07:10 AM
