Swap question
Old May 18, 2005 | 10:18 PM
CB7DOHC's Avatar
Default Swap question
hey i found a wrecked 1995 2.2 VTEC accord fore sale....im wanting to know if its possible to swap just the head or long block to my 91 5spd accord? see where im going w/ this? will just the motor swap to my mounts and will my headers, exhaust, transmission, ect... still bolt up since its still an f22a sohc just VTEC? if so PIMP JUICE... thanks for any inputs
Old May 19, 2005 | 05:10 AM
Lostcb7's Avatar
Default Re: Swap question (91crxb16a)
fits pretty easily, definately check out http://www.cb7tuner.com for TONS of info on this swap
Old May 19, 2005 | 08:13 AM
90accorddx's Avatar
Default Re: Swap question (Lostcb7)
it should fit in there fine but you will need the ECU for the b motor and im not sure if the tranny is different or not i know the 4th gens and the cable shift tranny
Old May 19, 2005 | 01:31 PM
TxTuner
Guest
Posts: n/a
Default Re: Swap question (90accorddx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90accorddx &raquo;</TD></TR><TR><TD CLASS="quote">it should fit in there fine but you will need the ECU for the b motor and im not sure if the tranny is different or not i know the 4th gens and the cable shift tranny </TD></TR></TABLE>
It was funny reading this. But then it got funnier when I was reading through your sig. If your gonna flame others, better have your **** straight.
Old May 19, 2005 | 01:42 PM
dmurphy2k3's Avatar
Default Re: Swap question (TxTuner)
The 1995s have a f22b1 which means that the header from the 1991(f22a) will not fit. You also will have to add a few things to add vtec (ecu, some sort of stolinoid, and oil line I think.) The transmission will work.
Old May 19, 2005 | 03:44 PM
LookingForVTEC's Avatar
Just swap the whole motor into you car. Save yourself the head ache
Old May 20, 2005 | 06:00 AM
iwubmybb4's Avatar
Default Re: Swap question (LookingForVTEC)
if you want vtec get an H22 :-D
shadowm891
Jan 23, 2008 04:15 PM
SKSyphen
Aug 21, 2006 06:48 PM
s2kveilside
Honda S2000
19
Sep 28, 2005 11:33 AM
Otherguy
Feb 13, 2005 04:59 PM
SOHC Gord
Jun 10, 2004 08:20 AM
