Putting in Pistons and Rod bolt threads hit crank journal and Scared. OK OR NO..
Old May 18, 2005 | 08:12 PM
volcom40street's Avatar
Default Putting in Pistons and Rod bolt threads hit crank journal and Scared. OK OR NO..
I'm such an idiot. SH**T, F*CK, dam, ..........
Is this going to be a problem or not. As I was tapping the piston into the cylinder I fogot to move the crank to it lowest spot for the cylcinder i was doing and hit the BRAND NEW MICORPOLISHED JOURNAL I SPENT $80 DOLLARS ON.
Do you think I can take some High grit Sandpaper a go over it lightly or...?
You can see it and running my finger nail across is horrible. I think I can rub it out though. Give me some insite helllllllllllpppppp.
I have new bearing but dont want to build this engine if I'm going to have to take it apart again.
Old May 18, 2005 | 08:51 PM
Tmack's Avatar
take the crank back and get them to fix it.
Old May 18, 2005 | 10:06 PM
5thgenallmotor's Avatar
Default Re: (Tmack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tmack &raquo;</TD></TR><TR><TD CLASS="quote">take the crank back and get them to fix it. </TD></TR></TABLE>
Next time use a piece of vacuum hose on the rod bolts so if you do it again it doesn't hurt anything. Good luck!
Old May 18, 2005 | 10:17 PM
hybrid_vtec's Avatar
Default Re: (5thgenallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgenallmotor &raquo;</TD></TR><TR><TD CLASS="quote">
Next time use a piece of vacuum hose on the rod bolts so if you do it again it doesn't hurt anything. Good luck!</TD></TR></TABLE>
Yes, use rubber hose on the rod bolts to prevent them from damaging anything.
Old May 19, 2005 | 12:51 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Putting in Pistons and Rod bolt threads hit crank journal and Scared. OK OR NO.. (volcom40street
Take the crank back to the machine shop and have them fix it, do not try and sand it out yourself.
Old May 19, 2005 | 04:55 AM
743power's Avatar
take it back and hope that it can be polished out without going with undersize bearings
next time do like the other guys said. vacuum hose, fuel line, duct tape, etc. on the bolts
Old May 19, 2005 | 08:10 AM
DavidT or VajT's Avatar
LOL, do what everyone is telling you dammit! Take it baaack!
TypeRMOBBiN209
15
Aug 11, 2023 05:19 PM
Z0831xiz
Apr 26, 2015 03:56 PM
17
Feb 5, 2008 07:55 PM
Lil_Jon
Apr 6, 2007 09:36 PM
deez nuts
Mar 31, 2005 07:04 PM
