how to change a IACV gasket
ok i dont have a manual, yes im ghetto and really should go out and get one, now i have a gasket for the IACV with the metal mesh filter on it, and this is for my b16a intake manifold, now do i have to take off the t-body to get to this, should i also get a t-body gasket, if not what do i use to get the screws out, are they torx, or allen, i cant really see...
and i mean Idle Air control valve not electric air control...unless they are the same, but my gasket looks nothing like it at all...
goddam geocities bandwith...hold on ill try something else...
[Modified by crxgator, 10:56 AM 2/6/2002]
[Modified by crxgator, 10:57 AM 2/6/2002]
is it this...
or this...
im leaning toward the tbody still, that is what i was told, but i still need to know how to get it out...
From: A place where stupidity runs rampant aka NorCal
That is your IAC, all thats holding it in is 12mm bolts, it will have 2 coolant lines attached to it, 1 coming from the throttle body and one going to under the intake manifold. You should be able to just take the bolts out, replace the gasket while its still in the car, and then reinstall it.
-Todd
Morasso
Feb 3, 2008 10:00 AM
ULTRA911
Mar 4, 2003 10:00 AM
