not enough..
you need to do some more research.
fuel, spark, ignition.
turn up the pressure without adjusting any of the three above gives you a great see-thru engine.
get "maximum boost", by Corky Bell. it's a book.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kung fu grip »</TD></TR><TR><TD CLASS="quote">
See-thru engine, that's funny, only because I had one once.
Seriously kung fu is right, just turning up the boost without adjusting the rest of the inputs is just going to create a big mess. You may want to snoop around over in the f/i forum. Lots of guys doing black magic over there, but be careful they will make your head spin pretty fast.
i agree with everyone's above posts.
But, if you really want to do it; get k-pro, larger injectors, and possibly cold spark plugs. And you'll be set for high boost.
Keep in mind that your turbo might loose efficiency if you put boost too high.
Josh_With_The_S2K
Honda S2000
28
Jan 27, 2008 06:54 AM
