MSD Blaster Cap is not wokring at all!!!!! Need Help and Fast!!!
Old May 18, 2005 | 05:15 PM
Truecure's Avatar
Default MSD Blaster Cap is not wokring at all!!!!! Need Help and Fast!!!
I installed my MSD Power Cap and Blaster 2 ignition external coil. And I unscrewed the postive and negative wires and directly connected the to the external coil.
My thought was once this was done the internal Coil is bypass and the car would run off of the external coil.
I've tried to crank my Teg several times and I'm getting nothing!!!!
What could I have done wrong!!! Please Help???????????????
Thanks Ahead of time guys!!!!!!
Old May 18, 2005 | 05:17 PM
RS DC4 94's Avatar
Default Re: MSD Blaster Cap is not wokring at all!!!!! Need Help and Fast!!! (Truecure)
You have to take the Internal Coil out of the dist.
Old May 18, 2005 | 05:38 PM
gsrious's Avatar
are you just trying to use the blaster coil and the cap for high voltage output???
Old May 19, 2005 | 02:44 AM
Truecure's Avatar
Default Re: MSD Blaster Cap is not wokring at all!!!!! Need Help and Fast!!! (red dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red dc2 &raquo;</TD></TR><TR><TD CLASS="quote">are you just trying to use the blaster coil and the cap for high voltage output???</TD></TR></TABLE>
Actually yes and no. It was time to change my distributor cap and rotor. So I decided to upgrade Msd. But I didn't know you needed a external coil. So I bought the Blaster2 and now I not getting anyting???
Old May 19, 2005 | 03:26 AM
mr.beeks's Avatar
it seems that you are not hooking up the 5th wire....
Old May 19, 2005 | 05:15 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: MSD Blaster Cap is not wokring at all!!!!! Need Help and Fast!!! (RS DC4 94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS DC4 94 &raquo;</TD></TR><TR><TD CLASS="quote">You have to take the Internal Coil out of the dist.</TD></TR></TABLE>
Pretty much that, you have to empty out your distributor if your using the external Msd pack.
Old May 19, 2005 | 10:13 AM
Truecure's Avatar
The Msd Power Cap and Blaster coil are working now. So far so good!!
Thanks Again you guys for all your help I really appreciated!!!
dmossdrum91
Sep 8, 2015 02:44 PM
honda_SiRII94
Apr 9, 2007 08:14 AM
SpoolnByYou
Mar 25, 2006 09:10 AM
