Popping noise(front driver side) and sluggish acceleration ...help
Old May 18, 2005 | 03:42 PM
Wesb18DB8's Avatar
Default Popping noise(front driver side) and sluggish acceleration ...help
I replaced my front torque mounts and put in Energy Suspension bushings...and i'm still getting this popping noise when i go over bumps. Also when i'm accelerating I get this loud vibration throughout the car and even the gas pedal. the car seems sluggish and feels like the motor is moving around alot and holding it's self back on normal acceleration...please help...it's been going on for a while...thanks
Old May 18, 2005 | 03:49 PM
egtype-r's Avatar
Default Re: Popping noise(front driver side) and sluggish acceleration ...help (Wesb18DB8)
TTT
Old May 25, 2005 | 08:05 PM
WakeSpliter's Avatar
I'm having similar problems as well. I have B16A and it just doesn't feel as snappy on accelleration as it used to. The car also makes a really low frequency vibration when i accelerate hard, kind like something is dragging, like a wheel bearing or something
Old May 25, 2005 | 09:09 PM
civicgsr19's Avatar
Did you do the obvious? (make sure all the mounts were tight?)
Did you replace the rear mount, when that one gets bad, it will allow the engine to come into contact with the car, making a very loud noise pretty much all the time.
Pop your hood and see if you can rock the motor back and fourth.
Old May 26, 2005 | 06:14 PM
Wesb18DB8's Avatar
Default Re: Popping noise(front driver side) and sluggish acceleration ...help (civicgsr19)
I just replaced my front torque mounts and rear engine mount with Energy Suspension Bushings...so thats not it...also when i put on the brakes it vibrate a little now. I'm thinking it might be a tuning problem
Old May 26, 2005 | 09:16 PM
chadmasterc's Avatar
Popping noise might be your axles? i need to replace mine cause they click and pop.
MolecularIntegra
Jul 11, 2017 08:34 PM
sedorbrian
Feb 1, 2012 01:53 AM
daonei
Oct 12, 2007 01:00 PM
n8dogg
Apr 17, 2005 10:13 AM
Infinity_Racer
Feb 10, 2004 04:06 PM
