b16 usdm in to a honda civic 97 HELP HELP HELP HELP???????????
Old May 18, 2005 | 03:39 PM
shyxboy's Avatar
Default b16 usdm in to a honda civic 97 HELP HELP HELP HELP???????????
when you drop in the b16 usdm in to a 97 civic do you have to change the indash harness to a 99 - 00 ???? or will the complete swap work with out changing anything in side the car??? what i mean with a complete swap is " ecu, axles, engine, engine harness..." since its a 99 - 00 engine .... ??? can anyone answer that i
Old May 18, 2005 | 04:35 PM
97civicdx's Avatar
Default Re: b16 usdm in to a honda civic 97 HELP HELP HELP HELP??????????? (shyxboy)
This has been covered many times already.
Use your 97 engine harness and modify it with the engine harness plugs etc etc. Adding wires for the sensors that the ecu needs.
Old May 18, 2005 | 05:15 PM
shyxboy's Avatar
Default Re: b16 usdm in to a honda civic 97 HELP HELP HELP HELP??????????? (97civicdx)
theres no other way of doing it??? dont really wanna cut and pasts things??? sorry if that a stupid question but yea
Old May 18, 2005 | 06:18 PM
hondadriver's Avatar
You can't use a 99-00 civic si engine harness becasue the 99-00 have 2 plugs that go to the ecu from the engine and the third one is wired into the car. So its not possible. Just stick with you 97 engine harness and add your vtec, vtec pressure, and knock sensor. Or if you have a 97 ex then they should all already be there. Then it depends on what ecu you are gonna use, you can buy a obd2 to obd1 converter harness if you plan on using a obd1 ecu. or if you decide to use a 99-00 civic si ecu then you can buy a obd2a to obd2b conversion harness. What I did with my jdm 2nd gen b16a in my 98 lx, I boughth a 99-00 civic si engine harness. And what i did was i pulled the ecu plugs off the 98 engine harness and removed the plugs off the 99-00 civic si engine harness and with the helms book, I repined the 3 correct plugs so that I can keep the 98 engine harness on my car and plug in a 99 si ecu. It was alot more work. But I love doing it, i did my friends wire harness in his 92 civic with a 2nd gen b16a, and another crx si with a 1st gen b16a. And all three run like champs no codes, so "i'm 3 for 3. So do what I say and what everyone else says, keep the 97 engine harness and work off that.
Old May 18, 2005 | 08:29 PM
shyxboy's Avatar
Default Re: b16 usdm in to a honda civic 97 HELP HELP HELP HELP??????????? (hondadriver)
can you use any stock ecu like a gsr or type r etc.... with just changing the pins???
Old May 19, 2005 | 01:13 AM
97civicdx's Avatar
No.
92-95 civics have a 2 pc harness, exactly like the integras.
96 and up civics have a 1 pc harness
Reread post above.
Peace
Old May 19, 2005 | 01:41 PM
No, becasue gsr's have the secondary butterflies in the intake manifold. and the b16's dont, nor do the type r's. You can use a p73 ecu which is a type r ecu and it plugs right into the 96-98 engine harness. The ecu will plug right in but I never looked at the pinout. So I'm 98% sure the pinout should be the same, but not 100%. And if you do decide to use a type r ecu you will have to be carefull, because the type r redlines at 8600, and the si redlines at 8200. The si is not made to go passed 8200. So you would have to watch for that everytime you race or decide to go up into the high rpms.
AaronDavis
Dec 9, 2020 11:55 PM
ThrowSomeDs
Apr 17, 2011 04:14 PM
j.orr
Mar 22, 2010 11:10 AM
blkhatch97
Dec 10, 2005 05:45 PM
endless_pain
Mar 25, 2005 11:38 AM
