0bd0 injectors
Old May 18, 2005 | 11:01 AM
gutted-dx's Avatar
Default 0bd0 injectors
Are all obd0 injectors the same.
Old May 18, 2005 | 11:02 AM
EP3_05's Avatar
Default Re: 0bd0 injectors (gutted-dx)
Yes they are all 240cc peak and hold injectors(low impedance).
EDIT: I am talking about mpfi inectors. I am not sure if the dpfi(dx, std, lx) injectors are different.
Old May 18, 2005 | 02:31 PM
Serdar's Avatar
Default Re: 0bd0 injectors (91civic)
Hf injectors also?
Old May 18, 2005 | 02:34 PM
krazie1's Avatar
BANNED
Default Re: 0bd0 injectors (Serdar)
well it depends I don't think the SOHC motors uses 240cc
there's might be less
Old May 19, 2005 | 04:58 AM
gutted-dx's Avatar
Well that might be my problem i switched to HF injectors in my DOHC ZC. i kinda runs like poop
Old May 19, 2005 | 05:33 AM
Autoworks's Avatar
Default Re: (gutted-dx)
I was told yesturday that the 92-95 Prelude (OBD1) injectors that are 330cc work fine in the 88-91 CRX using the same resistor boxes.
Old May 19, 2005 | 05:44 AM
CRX_Control's Avatar
Default Re: (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted-dx &raquo;</TD></TR><TR><TD CLASS="quote">Well that might be my problem i switched to HF injectors in my DOHC ZC. i kinda runs like poop</TD></TR></TABLE>
are they brand new? or used , they run like crap eventually if old .
Old May 19, 2005 | 06:25 AM
gutted-dx's Avatar
Used i took them out of the HF because i knew they worked
Old May 19, 2005 | 07:18 AM
HumanResource's Avatar
NON NOBD 88-91 HF injectors = 180cc low imp
find some off any other NON OBD MPFI engine.
Old May 19, 2005 | 07:19 AM
DOUBLE POST
DANGIT!!!
Old May 19, 2005 | 09:30 AM
gutted-dx's Avatar
Sounds good
Old May 23, 2005 | 09:28 AM
gutted-dx's Avatar
My car runs perfect now, switched back to the ZC injectors
Old May 23, 2005 | 09:50 AM
kaoss_11's Avatar
B A N N E D
how long do oem and aftermarket like rc last for
Old May 23, 2005 | 10:02 AM
Tyson's Avatar
what other OBD0 PGMFI injectors can you use for a d16a6?
Old May 23, 2005 | 04:39 PM
gutted-dx's Avatar
I'd say they last pretty long, unless something got in your fuel system
harmonator84
Jan 19, 2007 02:57 PM
sporkcrx
Oct 21, 2006 01:07 PM
JDMb16ef
Mar 17, 2005 01:09 AM
junkyardRx
Sep 6, 2004 04:02 AM
rextec
Oct 10, 2003 05:08 AM
