Honda Accord shakes slightly when I accelerate, then is fine with full acceleration
Old May 18, 2005 | 10:51 AM
LostSoul's Avatar
Default Honda Accord shakes slightly when I accelerate, then is fine with full acceleration
This has me baffled and a bit worried. 94 honda accord with 156K miles, timing belt replace 3k miles ago, as was the radiator and thermostat.
the car shakes slightly when i begin to accelerate but is fine when i really give it some gas. not sure if this is something I should worry about or not.
any ideas would be appreciated.
Old May 18, 2005 | 07:42 PM
deserthonda's Avatar
was it ok before t-belt job?? if so have recheck work balancer shafts could be misaligned
Old May 18, 2005 | 07:48 PM
momstaxi's Avatar
Default Re: Honda Accord shakes slightly when I accelerate, then is fine with full acceleration (LostSoul)
some possibilitys could be, worn wheel bearings, worn driveaxle, like stated above the balancer shafts out of alignment...
has it done this ever since the timing belt, if so that is the most likley cause, or it could also be out of balance wheel, as i had that problem and it would shake when really driving slow but would seem to fade away as mph increased...
Old May 18, 2005 | 08:50 PM
another thing i thought of chk your tires make sure you don't have a separated ply
Old May 19, 2005 | 04:47 AM
LostSoul's Avatar
Thanks for the responses. This hasn't happened since the timing belt replacement, only in the last few weeks. It seems that my idle might be running a bit low (750 rpm in neutral). Could that be the problem?
Old May 24, 2005 | 04:56 AM
LostSoul's Avatar
Bump
Old May 24, 2005 | 06:08 AM
Confuc1ous's Avatar
could this have anything to do with your engine mounts perhaps?
Old May 24, 2005 | 09:56 PM
CB7VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostSoul &raquo;</TD></TR><TR><TD CLASS="quote">It seems that my idle might be running a bit low (750 rpm in neutral). Could that be the problem?</TD></TR></TABLE>
idle is fine as long as it isnt fluctuating
crxaddikt
Aug 16, 2017 03:44 PM
RA022626
Jul 2, 2015 10:39 AM
faran
Oct 13, 2009 10:33 PM
BlazeTeck2000
Jan 30, 2005 02:22 PM
