***MSD wiring problem***
Old May 18, 2005 | 10:24 AM
x-1's Avatar
x-1
Default ***MSD wiring problem***
On a 94 prelude vtec.
I am trying to install the damn msd. I need help with two wires. The red and the white wires that are comming from the MSD. Where the hell do they go? I got four wires inside the dizzy that are going to the ignitor. One is yellow with a green stripe. One solid green and one solid blue and one black/yellow stripe. On the plug where i disconnected the external coil, there are 3 wires. One is yellow. Another black/yellow stripe and a blue one. Can someone help me where to connect these two wires (red and white).
Modified by x-1 at 11:40 AM 5/18/2005
Modified by x-1 at 12:03 PM 5/18/2005
Old May 18, 2005 | 10:41 AM
Lewdin' Incognito's Avatar
Default Re: ***MSD wiring problem*** (x-1)
Overboost.com - How To: Install an MSD Ignition
http://www.overboost.com/story.asp?id=265
They actually do it on a Civic, but it's pretty good.
Old May 18, 2005 | 11:04 AM
x-1's Avatar
x-1
Default Re: ***MSD wiring problem*** (Lewdin' Incognito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin’ Incognito &raquo;</TD></TR><TR><TD CLASS="quote">Overboost.com - How To: Install an MSD Ignition
They actually do it on a Civic, but it's pretty good.</TD></TR></TABLE>
civic and prelude has different color wires.
Old May 18, 2005 | 11:32 AM
mswanson00's Avatar
It wont hurt anything if you hook it up wrong, just don't leave it on long, If I remember right, I have the Greens together and the blue and blacks together. Try and crank it, if it doesn't or it starts running like ****.. shut it off and retry the wiring. Just try the way I said first.. but it's been a while.
Old May 18, 2005 | 12:58 PM
graphic's Avatar
on my 98 prelude i hooked up the black/yellow and the yellow to the red wire and the blue to the white..as for the ignitor wires i didn't hook them up to anything...
Proceed with caution..
Old May 18, 2005 | 03:11 PM
bgm93srv's Avatar
Default Re: ***MSD wiring problem*** (graphic)
Ok since I just had mine installed last week I still have the manual. The yellow and black as well as the yellow (original coil +) connect to the red. The blue one (origninal coil -) connects to the white. These are the wires from the plug of the original coil. Assuming you are keeping the factory coil the orange goes back to the yellow/ black and yellow and the black goes to the blue. Hope that helps
Old May 18, 2005 | 06:18 PM
x-1's Avatar
x-1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graphic &raquo;</TD></TR><TR><TD CLASS="quote">
Tnx, that is what i did and every thing is cool.
Old May 18, 2005 | 06:21 PM
x-1's Avatar
x-1
Default Re: ***MSD wiring problem*** (bgm93srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgm93srv &raquo;</TD></TR><TR><TD CLASS="quote">Ok since I just had mine installed last week I still have the manual. The yellow and black as well as the yellow (original coil +) connect to the red. The blue one (origninal coil -) connects to the white. These are the wires from the plug of the original coil. Assuming you are keeping the factory coil the orange goes back to the yellow/ black and yellow and the black goes to the blue. Hope that helps</TD></TR></TABLE>
I actualy went with the SS coil and everything is good, Thnx.
vtecturboteg22
May 4, 2005 05:54 PM
asnboi_512
Aug 2, 2004 12:28 PM
.honda.
Mar 2, 2004 05:35 AM
Shakes
Jan 9, 2004 02:49 PM
slow02ss camaro
Nov 7, 2003 02:44 PM
