Need some help 02 problems
Ive replaced the o2 but it keeps throwing code 41 (heater signal) I've tried 2 02 sensors, checked wires with test light and there gettin signal from the ecu. Dont really know what else to try besides maybe a different ecu. Any other help would be much appreciated.
did you reset the ECU after installing??
try switching the 2 wires that are the same color. some are black, some are white. just reverse those 2 and reset the ECU
if its the code 41 then your wiring is messed up somehow. If these o2 sensors are universal ones that you wired up yourself, then you better know how to solder because you absolutely HAVE TO solder your connections.
SOHC_Brian
Nov 13, 2005 08:17 AM
ATS*Mark
Mar 17, 2004 05:08 AM
