water pump part number
Old May 18, 2005 | 06:13 AM
JDM97dc2R's Avatar
Default water pump part number
ok i used the search engine i was reading and now i have a confussion
i am looking for the part number of a water pump for an JDM ITR engine
i saw ppl posting that is 19200-p72-013 and also saw ppl posting that is 19200-p72-003
which one is the correct one
Old May 18, 2005 | 09:45 AM
ebelp's Avatar
Default Re: water pump part number (JDM97dc2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97dc2R &raquo;</TD></TR><TR><TD CLASS="quote"> 19200-p72-013 </TD></TR></TABLE>
That one.
The picture of the water pump in the other thread with the 19200-P72-003 part number was from a 94 GSR (that picture was just posted to show the gasket). The part number changed to 19200-P72-013 for all 1996 and newer Integras w/ VTEC engines. I'm assuming this relates to the switch to OBDII in 1996 also.
Old May 18, 2005 | 10:43 AM
JDMitr54's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97dc2R &raquo;</TD></TR><TR><TD CLASS="quote">19200-p72-013</TD></TR></TABLE>
i agree
Old May 18, 2005 | 04:29 PM
whiteGSR's Avatar
Default Re: water pump part number (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">
That one.
The picture of the water pump in the other thread with the 19200-P72-003 part number was from a 94 GSR (that picture was just posted to show the gasket). The part number changed to 19200-P72-013 for all 1996 and newer Integras w/ VTEC engines. I'm assuming this relates to the switch to OBDII in 1996 also.</TD></TR></TABLE>
crap, i just bought the 19200-P72-013 water pump...has anyone installed it in a 94-95 engine w/o any problems?
Old May 18, 2005 | 05:07 PM
B2FiNiTY's Avatar
Default Re: water pump part number (whiteGSR)
If you bought the wrong one, return it?
Old May 18, 2005 | 09:41 PM
JDM97dc2R's Avatar
thanks for the answer ebelp...
Old May 23, 2005 | 11:46 PM
110 South's Avatar
The part number is just supersceeded to the 013 suffix. There is no difference between the 003 and the 013. All B-series VTEC waterpumps are the same.
-Brandon
Old May 24, 2005 | 12:43 AM
ibme_uk's Avatar
Default Re: water pump part number (110 South)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 110 South &raquo;</TD></TR><TR><TD CLASS="quote">The part number is just supersceeded to the 013 suffix. There is no difference between the 003 and the 013. All B-series VTEC waterpumps are the same.
-Brandon</TD></TR></TABLE>
Not quite true
http://www.team-integra.net/fo...15789
Old May 24, 2005 | 12:45 AM
B2FiNiTY's Avatar
Default Re: water pump part number (ibme_uk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibme_uk &raquo;</TD></TR><TR><TD CLASS="quote">Not quite true
http://www.team-integra.net/fo...15789</TD></TR></TABLE>
Your link just proves what 110 south just said. b-series vtec water pumps are the same.
Old May 24, 2005 | 12:50 AM
ibme_uk's Avatar
Default Re: water pump part number (B2FiNiTY)
That one.
After reading this i thought that only the 19200-P72-013 was a vtec pump?
Old May 24, 2005 | 03:15 AM
JDM97dc2R's Avatar
u guys need to read the post in the link WOW genius those honda ppl
Old May 27, 2005 | 12:08 AM
110 South's Avatar
Thank you Dennis!
Old May 27, 2005 | 04:52 PM
ildknyli's Avatar
Pm'd
Old Jun 1, 2005 | 08:19 PM
Teglessb18's Avatar
Default Re: water pump part number (ildknyli)
so will a ITR water pump fit a b17a? im assuming so because it seems by that article that all vtec water pumps are the same.?????
Old Jun 4, 2005 | 11:51 PM
110 South's Avatar
Default Re: water pump part number (Teglessb18)
yes
rohec04
Oct 27, 2007 05:56 PM
G2K
Nov 19, 2006 09:30 AM
B18 CYA
12
Sep 3, 2006 08:27 AM
AllmeGSR
Jan 22, 2005 08:27 PM
Focus2point3
Nov 21, 2004 12:00 PM
