Piston to Deck Height for D16Z6 with PM6 Pistons...
Old May 17, 2005 | 09:23 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Piston to Deck Height for D16Z6 with PM6 Pistons...
Anyone know what it is?
http://www.knology.net/%7Ejediklc/D.htm
I don't know what to punch in.
Old May 18, 2005 | 08:32 AM
GapxGuy's Avatar
Default Re: Piston to Deck Height for D16Z6 with PM6 Pistons... (GapxGuy)
BUmp
Old May 18, 2005 | 08:59 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
0.020"...consider it a stock a6 bottom end.
deck heights, strokes, and rod lengths are identical between the sohc d16s.
Old May 18, 2005 | 10:09 AM
GapxGuy's Avatar
Default Re: Piston to Deck Height for D16Z6 with PM6 Pistons... (fastcrxsi90)
So if I'm using any D16 block, the PTDH would just be the pistons I'm using in that block? If I'm using D16A1 pistons in a D16 block, I would just select ZC as the PTDH?
Old May 25, 2005 | 08:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy &raquo;</TD></TR><TR><TD CLASS="quote">So if I'm using any D16 block, the PTDH would just be the pistons I'm using in that block? If I'm using D16A1 pistons in a D16 block, I would just select ZC as the PTDH?</TD></TR></TABLE>
if your staying between d16s with the same rod length and stroke...then for that calculator pick your PTDH to match the pistons you are using.
if your using pistons from a d15 in your d16 or visa versa then you have to calculate your new PTDH....its an easy calculation.
cluelessmale
May 28, 2007 07:43 PM
evade this honda
Jul 28, 2006 07:20 PM
ekVtecPower
Jun 27, 2006 11:18 AM
Layziebtnh055
Jun 26, 2004 01:54 PM
91hondacrx
Jun 18, 2003 03:08 PM
