D15 (seriously) motor debate
Old May 17, 2005 | 08:40 PM
Civicslayr's Avatar
Default D15 (seriously) motor debate
have two count 'em two d15's laying around. One in my 89 driver, and one in my 91 parts car. both have 250,000 miles on them. I have good relations with a local machine shop, so this stuff probably would be discounted.
I would like to take the block out of the 91 and have the shop bore it out a little. I'm a muscle car guy, so im not sure, but whats the standered overbore when you rebuild hondas. I'd like to rebuild that motor (mabey a bigger bore) and put a blower on it. I know that the hf motors have more compression than the si's, so my question is "if i get this motor over bored a little, would i have the screw with the piggy back unit that comes wth the jackson racing blower kit. Also I know those kits are for si's, would i have tro run an si ecu, would boring the motor to 1.6, or 1.7 make it basicly the same as a d16, but with higher compression." Just spitballin, trying to use what i got u know. I don't see any d15s bored and blown, so i figured i'd do it to be different, how stout are the d15's?
Old May 17, 2005 | 08:56 PM
FalkenSiR's Avatar
Default Re: D15 (seriously) motor debate (Civicslayr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicslayr &raquo;</TD></TR><TR><TD CLASS="quote">...so i figured i'd do it to be different, how stout are the d15's?</TD></TR></TABLE>
Props for being so brave but the D15s are just crap. Small displacement, not a lot of aftermarket support (ie compared to a d16), and do you ever hear of an allmotor D15 ?? They must not be all that great to build up as a performance motor.
You are better off stepping .1 L in displacement and saying hi to an all new world of performance.
Old May 17, 2005 | 09:10 PM
91civicEX's Avatar
Default Re: D15 (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">
You are better off stepping .1 L in displacement and saying hi to an all new world of performance.</TD></TR></TABLE>
d15 and a d16 is practically the same motor. your right d15 is a bit weaker due to smaller crank journals. but the aftermarket for em is EXACTLY the same. assuming you dont wanna get forged internals on that d15. theyre not ideal as a performance motor but if you got em layin around then theyll work. standard overboare is .25mm i think. check on http://www.hondaautomotiveparts.com to see what is the biggest piston they sell (stock replacement)
Frost7177
Jul 2, 2008 08:44 PM
prelude1897
Apr 26, 2006 11:46 PM
atmosphere
12
Apr 8, 2006 02:02 PM
scorched0
12
Nov 14, 2003 12:42 PM
servion
Apr 21, 2003 01:56 PM
