tranny or clutch problem????
Old May 17, 2005 | 08:18 PM
lilman4o8's Avatar
Default tranny or clutch problem????
ok, i tried to look up this problem but i coudlnt find anything that related to this.
today i drovet o work and everything was ok. hours later i was bout to drive mai car in to work on it, out of no where it wouldnt go into reverse, my co worker and i try to force it into reverse and it still didnt work, 10 minutes later, i finally got it into reverse...... now i couldnt get it out. my other co worker came out n got it to work fine, he said he pumped the clutch a couple of times then it'll shift good. but after this incident shifting into reverse been a bitch! one guy said it's clutch, but da guy i bought it from said it's a new cltuch, n e one kno anything about this, thanks.
Old May 18, 2005 | 04:02 AM
JimBlake's Avatar
Default Re: tranny or clutch problem???? (lilman4o8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilman4o8 &raquo;</TD></TR><TR><TD CLASS="quote">... my other co worker came out n got it to work fine, he said he pumped the clutch a couple of times then it'll shift good...</TD></TR></TABLE>If you can make it better by pumping the clutch pedal, then it's probably air in the clutch hydraulic lines. Bleed your clutch.
Old May 18, 2005 | 08:29 PM
lilman4o8's Avatar
how do i bleed my clutch, sorry, i'm not really educated a lot on cars. still learnin in process
Old May 18, 2005 | 08:46 PM
raceACCORDingly's Avatar
my reverse is stubborn i have to put it into a forward gear and move up a little before getting into reverse or i have to fully depress the clutch and slowly release it while putting it into reverse.
noxon511
Mar 15, 2014 08:42 PM
dohc_profile
Nov 6, 2007 06:11 PM
nk2k2
Oct 11, 2006 12:50 PM
97turboteg
May 13, 2006 02:49 PM
DXRiCE98
Feb 4, 2004 08:48 PM
