Honda S2000 Honda S2000
TSB update/recall
Old May 17, 2005 | 07:45 PM
01itr320's Avatar
Default TSB update/recall
I saw someone mention something regarding TSB (Transmission?) update or recall. Just wondering what this really is and what it involves. Tried searching, but no luck. Thanks.
Old May 17, 2005 | 07:47 PM
Nishant's Avatar
Default Re: TSB update/recall (01itr320)
look below for answer
Modified by Nishant at 12:26 AM 5/18/2005
Old May 17, 2005 | 08:15 PM
Mr. Bagel's Avatar
Default Re: TSB update/recall (Nishant)
It's a 2000 year, as in... the one in his signature.
The TSB you are referring to, at least that I can recall, deals with decel clutch buzzing from ~4.5 down to 3K rpms. Quite annoying. They replaced the disk with different springs. I don't recall any other TSBs regarding the transmission, but I might be wrong on that.
Old May 17, 2005 | 08:28 PM
01itr320's Avatar
Default Re: TSB update/recall (Mr. Bagel)
Thanks for the help, my S really does seem to have a buzzing/vibration beneath the vehicle when I allow it to resonate down to lower speeds. Is this due to the car not having the update/recall completed? By the way, the car is a certified used Honda. Thanks.
Old May 17, 2005 | 08:29 PM
Nishant's Avatar
i would call the dealership to see if the TSB was done
Old May 17, 2005 | 08:31 PM
01itr320's Avatar
Thanks Nishant, I'll check.
Old May 18, 2005 | 05:40 AM
fknfast's Avatar
Nothing on the tranny. if the car is within warrenty theyll do the clutch disk. If they do, you better put an aftermarket setup in there if your goin to mod it while they do they labor.
Old May 18, 2005 | 07:02 AM
Honda Family's Avatar
Probably TSB 054 Clutch Disk Buzz
Zachary23
Nov 14, 2016 07:21 PM
NoobCR-V
Suspension & Brakes
Apr 25, 2008 08:41 AM
gooberguy31
Apr 15, 2008 05:43 PM
juevi (old)
Aug 21, 2006 12:31 PM
