really low idle
Old May 17, 2005 | 06:30 PM
drowzysleeper's Avatar
Default really low idle
rebuilt motor put high comp pistions in and re done the block with stock stuff now i idle really low what could it be? i got a d16y8
Old May 17, 2005 | 08:29 PM
Motor-Tek's Avatar
have you tried adjusting the idle?
Old May 17, 2005 | 08:30 PM
Status Sean's Avatar
Default Re: (Motor-Tek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motor-Tek &raquo;</TD></TR><TR><TD CLASS="quote">have you tried adjusting the idle?</TD></TR></TABLE>
Old May 17, 2005 | 09:04 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (rw92civic)
ignition timing, idle screw, iac, fiv, etc
Old May 17, 2005 | 09:38 PM
Audi RS4's Avatar
Lover
Default Re: really low idle (drowzysleeper)
try adjusting the idle.
Old May 17, 2005 | 11:15 PM
Bond's Avatar
Default Re: really low idle (Carparts-Auction.com)
I don't want to jack this thread, but I thought I could ask a quick question. I try to adjust my idle with the screw and it does nothing. I mean I can crew it in or out and there is no difference. I don't get it. Usually my low idle problem is when I let off the gas quickly the idle drops really low and stay's there. If I drop it slowly it's fine. I am at a lose because I can't figure out the problem. I do get a surging idle when engine is warming up. Can someone help me? I am losing my mind!
Old May 17, 2005 | 11:35 PM
riceburnerryan's Avatar
i didnt think it was that bad if it was a low idle.. sometimes my VAFC reads 699-705 but not anything lower.. but for the most part reads 775-800... so i donno how low the idle is ...
Old May 18, 2005 | 12:15 AM
Bond's Avatar
Default Re: (riceburnerryan)
The lowest I have seen my idle go was 400-450rpm. Didn't stall but it's way to low. I have had it with my intake manny. I think soon I will just replace the whole thing, but we will see. Anybody want a D15B7 intake manny with only 101 xxxkm on it in about a month or two?
Old May 18, 2005 | 03:33 AM
lilCivic's Avatar
Default Re: (Bond)
i have the same prob.....it was my 02 sensor, because my car was sucking gas and it was not moving, the idel would go down to 450 , try to put it on diagnostics.
Old May 18, 2005 | 01:40 PM
Default Re: (lilCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilCivic &raquo;</TD></TR><TR><TD CLASS="quote">i have the same prob.....it was my 02 sensor, because my car was sucking gas and it was not moving, the idel would go down to 450 , try to put it on diagnostics.</TD></TR></TABLE>
which o2 sensor, and where exactly is the idle screw?
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
minner
Oct 8, 2006 01:30 PM
