Piston Ring Gap for N/A Motor With Occasional Nitrous
Old May 17, 2005 | 05:55 PM
rmcdaniels's Avatar
Default Piston Ring Gap for N/A Motor With Occasional Nitrous
Building a B20 stroker for street and road course use. I was thinking I'd like to put nitrous on it for occasional use, especially drag racing, but mostly I'd just run it without it. Using JE 11.6:1 pistons, and ring gap is .015/.017 for all motor, .017/.018 for moderate nitrous use.
I have two questions:
1. Is that enough extra gap? I'll probably run a 100 shot on it. I know some guys who run .004 extra for nitrous, but not on Honda engines.
2. How much power will I lose from opening up the gap? Will it be worth the extra occasional boost from the nitrous to give up some full-time power?
Old May 17, 2005 | 08:06 PM
biotech0123's Avatar
Default Re: Piston Ring Gap for N/A Motor With Occasional Nitrous (rmcdaniels)
Im running stock ring gaps on my setup and I'll be squeezing 100+ nitrous, I was told that would be fine (per Endyn). Besides you said that you were not going to run it 24/7 so you should be fine if tuned properly.
1jdmek
33
Nov 26, 2007 07:10 PM
HONDAVTIS
Oct 20, 2006 08:45 AM
z6
Apr 20, 2004 06:46 PM
redteg1
Dec 31, 2001 11:18 PM
NewbieGuy
Oct 11, 2001 08:24 AM
