Valve adjustment problem
Old May 17, 2005 | 04:57 PM
milano2kdc2's Avatar
Default Valve adjustment problem
i was doing valve adjustment on my car today, stock cams, .006 intake and .007 exhaust and on cylinder #4, exhaust side, distributer side stud adjusts, but the guages dont fit. I tried turning it all the way left and right, it seems to have the same clearence. I can push the valve down to make it fit but that doesnt do any good.
Why doesnt it adjust?
Modified by milano2kdc2 at 5:01 AM 5/18/2005
Old May 17, 2005 | 07:32 PM
Lord Helmet's Avatar
Default Re: Valve adjustment problem (milano2kdc2)
Don't mean to make you sound like a idiot but you do know you adjust the stud that's on the rocker arm and not the actually nut. The nut is to tighten the stud down to the position you want the clearence it needs to be.
If that's not the case then maybe the stud's thread is stripped on the rocker arm.
Old May 17, 2005 | 08:01 PM
Default Re: Valve adjustment problem (Lord Helmet)
yes i meant the stud, not the nut. sorry for the confusion, and i can see the stud going up and down when im adjusting it
Old May 17, 2005 | 08:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milano2kdc2 &raquo;</TD></TR><TR><TD CLASS="quote">yes i meant the stud, not the nut. sorry for the confusion, and i can see the stud going up and down when im adjusting it</TD></TR></TABLE>
it doesn't get any tighter then?
Old May 17, 2005 | 08:39 PM
i guess it was just a one time thing, cause the problem seemed to have fixed itself, i drove it around for a bit, waited a few hours and tried again, and it adjusted normally
thx lord helmet for the help
Old May 17, 2005 | 08:42 PM
not a problem, that's what HT is here for
projekt-sol
12
Jan 3, 2008 07:41 PM
RoB316
May 31, 2007 06:16 PM
redDAinteg
Oct 28, 2005 07:51 PM
Alex Goodman
Jan 29, 2005 11:45 AM
JFG Kevin
May 12, 2004 03:44 PM
