90 CRX Si: B18A1; PR4 ECU; Red Blinking Light and cylinder 1 no fire
Old May 17, 2005 | 04:17 PM
ExplicitSnow's Avatar
Default 90 CRX Si: B18A1; PR4 ECU; Red Blinking Light and cylinder 1 no fire
anybody have any clues on whats happening? cylinder isnt firing at all...just replaced plugs, wires, cap and rotor...ecu started flashing a red dot in the middle
ecu is flashing constant for about 3 seconds, then flashing 3 times, then flashing 4 times...any help?
Old May 17, 2005 | 04:30 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: 90 CRX Si: B18A1; PR4 ECU; Red Blinking Light and cylinder 1 no fire (ExplicitSnow)
are they short or long flashes?
Old May 17, 2005 | 04:51 PM
Default Re: 90 CRX Si: B18A1; PR4 ECU; Red Blinking Light and cylinder 1 no fire (PURPLETERROR)
i found ecu codes 23 knock sensor, 14 IAC, 3 MAP and 5 MAP...thing is, harness that was supplied with swap doesnt have a connector for the IAC or TP...connector for MAP is pretty busted along with sensor, also TP sensor is trashed too...this swap is takin all my money and time...itll be worth it, hopefully
Old May 17, 2005 | 04:52 PM
mar778c's Avatar
Community Builder
Community Influencer
Based on the codes described, you have problem with your DPFI to MPFI wiring.
Codes 13 and 4
Default Re: 90 CRX Si: B18A1; PR4 ECU; Red Blinking Light and cylinder 1 no fire (mar778c)
why would there be a dpfi to mpfi wiring problem? vehicle was already mpfi from the factory...Si
Old May 17, 2005 | 05:07 PM
mar778c's Avatar
Community Builder
Whoops your right. Sorry I posted the wrong stuff.
That code 4 looks like a dead distributor. That is probably the main problem.
Modified by mar778c at 6:18 PM 5/17/2005
Modified by mar778c at 6:23 PM 5/17/2005
Old May 17, 2005 | 05:08 PM
link doesnt work
Old May 17, 2005 | 05:18 PM
mar778c's Avatar
Community Builder
Check the distributor.
Old May 17, 2005 | 05:40 PM
thats what im leaning too...this is an obd1 motor converted to obd0...i dont even think its an ls dizzy
Old May 17, 2005 | 06:19 PM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSnow &raquo;</TD></TR><TR><TD CLASS="quote">thats what im leaning too...this is an obd1 motor converted to obd0...i dont even think its an ls dizzy</TD></TR></TABLE>
Oh, okay. Check to make sure the injectors are working too.
Old May 19, 2005 | 04:38 AM
injectors are working...im sure its something to do with the map sensor and all the vacumm lines
thecorey
Dec 8, 2008 06:53 PM
andyt
Feb 20, 2007 06:08 PM
crxmadness
Sep 21, 2006 12:43 PM
UNDER PRESSURE
Jan 14, 2003 07:12 AM
89hb
Jan 6, 2003 06:11 AM
