Driverside Door wont open!
Old May 17, 2005 | 03:11 PM
Mr.Hankey's Avatar
Default Driverside Door wont open!
I installed an amp to my speakers inside my doors (had to take my door panel off to do it) and everything was working fine for about a week or two. Then i tried to get outta my car one day, and BONK my door wouldnt. So now my driverside door is stuck closed and i cant open it at all. So i went to the honda dealership and they said it would cost 700 bucks to fix!!! Now the dude told me that if i somehow could take the inner-door panel off (he says sometimes they can do it without breaking it off) then i would save 184 bucks. So im not sure what the **** to do, because i just dont have 700 or even 416 to pay on a stuck door. So if anyone can help me, id give them oral pleasure in return.
Edit: i was just kidding about the oral pleasure, but the backdoor is totally open for buisness.
Old May 17, 2005 | 03:25 PM
fw190bvi's Avatar
Default Re: Driverside Door wont open! (Mr.Hankey)
just pop off the door panel again, and reconnect the handle linkage
Old May 17, 2005 | 04:01 PM
Chiovnidca's Avatar
You didn't say what year it was. Is it a 90-93 model?
Old May 17, 2005 | 04:19 PM
deserthonda's Avatar
90-93 accord?? if it is what i think it is man you are in deep **** you better have those guys handle it,,to easier remove panel with door closed , remove frt seat it will make it a lot easier to work ,hope it is just a unattached rod if not it is a jammed up door latch there is an exact place you have to drill to brake the lock pin i used to have the pics where to drill and the presidure but lost them . maybe someone else here has them ,,,
Old May 17, 2005 | 04:37 PM
Mr.Hankey's Avatar
Its a 2000 accord coupe. I hope its not a jammed door latch, but im suspect it is. I tried to open the door and it was like it was about to open, then bam it stopped half way. I had my girlfriend close it from the outside, and then it wouldnt open up at all anymore.
I ripped off the inner-window linner, and i can now see straight down inside the door. When i try and open the door from the inside i can see the long bar from the door latch move a gold lever door in the door, but it doesnt open for some reason. It almost feels like its locked.
If someone could get some pictures of the latch deserthonda is talking about, and explain them, that would really help me out. But in the mean-time, imma have to climb over the passenger seat to get out of my car.
Old May 17, 2005 | 04:47 PM
Chiovnidca's Avatar
Default Re: (Mr.Hankey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Hankey &raquo;</TD></TR><TR><TD CLASS="quote"> It almost feels like its locked.
Have you given it a good lookover. Maybe it is locked. Try fiddling with the lock rods and the levers they move on the latch.
Old May 17, 2005 | 04:56 PM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Hankey &raquo;</TD></TR><TR><TD CLASS="quote">Its a 2000 accord coupe. I hope its not a jammed door latch, but im suspect it is. I tried to open the door and it was like it was about to open, then bam it stopped half way. I had my girlfriend close it from the outside, and then it wouldnt open up at all anymore.
If someone could get some pictures of the latch deserthonda is talking about, and explain them, that would really help me out. But in the mean-time, imma have to climb over the passenger seat to get out of my car.</TD></TR></TABLE>
you probably messed up the lock somehow...thats probably the culprit.....so make sure its all the way unlocked, and not caught on something.......it might appear to be unlocked if the door panel isnt popped back in correctly
Old May 17, 2005 | 05:29 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Hankey &raquo;</TD></TR><TR><TD CLASS="quote">I installed an amp to my speakers inside my doors (had to take my door panel off to do it) and everything was working fine for about a week or two. Then i tried to get outta my car one day, and BONK my door wouldnt. So now my driverside door is stuck closed and i cant open it at all. So i went to the honda dealership and they said it would cost 700 bucks to fix!!! Now the dude told me that if i somehow could take the inner-door panel off (he says sometimes they can do it without breaking it off) then i would save 184 bucks. So im not sure what the **** to do, because i just dont have 700 or even 416 to pay on a stuck door. So if anyone can help me, id give them oral pleasure in return.
This happened to my friend's 90 accord. His door got jammed. After long and hard seearching, he found a solution. He had to drill from inside the door at a certain spot to trigger the door actuator to open. This was very damn hard but saved him a new door. He went to junk yard and bought used actuator. Everything was fix.
Old May 18, 2005 | 12:44 PM
Mr.Hankey's Avatar
xbn83 i think thats what my problem is. Because i can see straight inside my door from the top and all the mechanism's are working just fine. But for some reason it just wont open. Im pretty convinced that im going to have to drill a hole in my door to either break the latch, or release it from its closed state. Do you know any pictures, or know where i have to drill to get to it? The honda rep. told me that, thats what they have to do to fix it. But obviously, i dont want to pay all that money to open my damn door.
Old May 18, 2005 | 12:57 PM
egzo04's Avatar
insted of paying that 700 or 400 or whatever u said, why dont u just break the door panel off yourself u said it was only 184 for that part, it be way cheaper.
Old May 18, 2005 | 01:50 PM
Mr.Hankey's Avatar
because its not 184 bucks for the panel, its 184 bucks in labor to get it off.
Old Feb 9, 2012 | 12:02 PM
aicrag6901's Avatar
i too am having this problem.i already destroyed my inner door panel.and can see the latch/ locking mechanism.everything seems to be working fine compared to the passenger side.i also think it has to do with the lock,so i pulled and pried to no avail. it would be greatly appreciated if you can find out where to drill the hole.
Old Feb 11, 2012 | 04:44 AM
Lost Again's Avatar
What year are you dealing with
http://techauto.awardspace.com/doorproblem.html
Old Feb 12, 2012 | 08:47 AM
75aces's Avatar
OP, what have you been able to figure out so far? Have you tried to see if the rod coming from the inner door handle to the acctuator is loose? That happened to me when I was replacing the lock acctuator. The door opended from the outside but not the inside. The culprit in my case was the rod came loose.
Old Feb 13, 2012 | 02:48 PM
aicrag6901's Avatar
I did the hole thing.pushed the rod and...nothing.so i cut it out and when i checkedmost all the plastic was broken and jammed the mechanism. Thanks for the help.i chalk it up to warm days and -20 nites.
Mychal71
Mar 20, 2022 01:32 PM
jtwellner
Dec 5, 2012 04:00 PM
todd bayliss
Jul 31, 2009 04:54 AM
srcv4life
Jan 29, 2006 12:42 PM
team952
Jul 21, 2005 07:24 PM
