got an alignment... need help quick
well i got an alignment. after the install of my progess non-adjustable camber kit and h&r sport springs on agxs.
I have two washers in the rear (on each bolt).
and the front is on the lower setting. (the hole for 1.5-2.0 lowering springs)
the guy said he had no trouble getting my toe to zero. but here is my camber issues
LEFT front .22 positive
RIGHT front .45 positive
LEFT rear .5 negative
RIGHT rear .5 negative
any ideas? maybe change the front cmaber kit thing?
positive camber is bad correct?
From: living too close to Karl, everythings busted, nc
depends on your plans for the car. It will understeer with twice as much negative camber in the rear. Otherwise, tires should wear ok. Personally, I would want -1.5 in the front, but that is just me
94AccordSedanEX
Oct 16, 2003 08:54 PM
